Hardware & Accessories Logo
Peter M.p Posted on Oct 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To program vizia leviton 24 hours on and off - Leviton Hardware & Accessories
Gene Haynes
Level 3:
  • Leviton Master 5,391 Answers
  • Posted on Nov 03, 2019
Gene Haynes
Leviton Master
Level 3:
Answers
5391
Questions
0
Helped
2605895
Points
14124
3 Related Answers
Anonymous
  • 2841 Answers
  • Posted on Jan 10, 2010
SOURCE: lost my wiring diagram for the leviton 6124 24 hour in-wall timer
Here you go.
Anonymous
  • Posted on May 05, 2012
SOURCE: programing instructions
you can look here http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=6124H-I&section=44955&minisite=10251 and click the adobe manual for programming instructions.
hansonmg
The Vanguardian
  • 531 Answers
  • Posted on Sep 07, 2016
SOURCE: Vizia Advanced 24-Hour Programmable Timer,White
Try lifting the door up until a click is heard.
Here is a video showing how, and there are 3 more related videos that are more in depth.
2answers
Leviton switches getting hot
Sounds as if there is to many watts going trough switch . Make sure it is rated for the lighting load.
Vizia VPT 24 - LCD not working, switch not working after power outage
faulty switch ? faulty breaker ? loose connection ?
get an electrician to test the circuit.
Programing instructions
HOW TO RESET TIME
6124 is 24-hour timer single-pole timer
Open following link for images, instruction manual, ez set instructions, and wiring instructions
http://waterheatertimer.org/Leviton-timers.html
1helpful
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
1helpful
How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Regular 3 way switch does not seem compatible with the Dimmer
you have the circuit mis-wired, the wire on the identified terminal( black screw or black wire on dimmer switch) is incorrect. Turn off power and swap one wire at a time to find the correct combination. The mistake could be at either switch so if the first does not help try the other.
Leviton rheostat switch has red glow inside
Change it out!!!!! Do not use. Could be a fire hazard
1helpful
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
I need to program a VRi06-1LX rf switch with a harmony remote
The VRi06-LX switch is in the Harmony database.  Log on to your account, select the Device tab and click on the Add Device button.  Select Home Automation/Light Controller from the drop down menu.  Then select Leviton and type in VRi06-LX for the model.  The next screen will show two models, select the VRi06-LX.  Go through the rest of the process to save the data and revise your programs if necessary.  The changes will not take effect until you update your remote.
Top Leviton Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
