Used 24v charger all nite now drill won't work.
SOURCE: Low voltage light flashing
I haven't worked on one of them in years but I looked at a breakdown and the parts are as I remember. Go to Milwaukeetool.com and under parts/service type in your model number and view the wiring diagram for an operational check procedure. I would first look at the cord and is the base sitting on 1/2 or greater plate steel. If rusted or painted you will loose some of the holding force. Also I don't know what motor you have but some of the larger units require a lot of amps to operate and it is possible that even though you plugged it in direct to wall the circuit wasn't sufficient to operate both units. Last resort call the tech dept. at Milwaukee and see if they have any ideas. That panel is a component part as you know and there were no replacement parts for it. Hope this helps if not let me know and I will do some more checking
SOURCE: need battery charger for black max 24v cordless
You need to call the Black Max parts department at 1-800-248-6657 from the hours of 6 am to 4 pm pacific time and place order over the phone.
SOURCE: wagner cordless drill ,the charger is not charging
If the charger is no longer working, then, take another
charger to charge the battery of your Wagner cordless
drill. If it charges, then, you have to replace your charger. It is already defective.
SOURCE: battery in charger overnight, red light flashing,
If only the red light is flashing then the battery is not charging at all. Ryobi identifies in the manual that batteries will not charge below 43 degress F. If your batteries and charger are in the garage in a cold climate, warm the batteries to room temp in the house and then try again. If the charge starts when the batteries are warm they will continue charging for the full cycle even in a cold area.
