SOURCE: Ice maker is freezing up
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
SOURCE: WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
