Question about Welding Tools
Wire feed does not work motor runs with 9v, battery and when you pull switch on handle contactor inside welder closes
6ya staff
SOURCE:
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Posted on Dec 23, 2008
luxur4
Ron Jones
  • 92 Answers
SOURCE: welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Posted on Jan 23, 2009
luxur4
Ron Jones
  • 92 Answers
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
Anonymous
SOURCE: Lincoln Pro-mig 175 w/ no wire feed but relay clicks fan runs
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with my MIG 175 Pro is the "voltage selector switch" (part # M15750-1). I took it apart and saw all of the contact points where corroded. I can hold the knob between two settings and the machine will work.
I have the same issue only after about a year of very light use. I am not sure how to prevent this from happening again.
Posted on Sep 04, 2009
Anonymous
SOURCE: Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Posted on Mar 21, 2010
I have a cig 220 I pull trigger to feed wire no wire or sounds happen welders fan is running wire isn't jammed and drive motor is working
first of all check the wiring from the machine to the torch then check that the thermal cut out light isn't illuminated, operate all switches and test on all settings, check the relay on the pcb and any contactors in there if all the above fails to find the fault then chances are a part on the pcb have failed
Oct 30, 2013 | Campbell Hausfeld Welding Tools
Murex transmig 405s
The contactor that controls the power to the tip (the heavy one) may be fused closed This interupts power to the primary winding if tip goes live without wire feeding.
. It may also be a shorted SCR on the control board if wire is feeding or it can also be a fused feed motor contactor- the small one.
Sep 24, 2012 | Welding Tools
I have a silver beauty 90200 mig welder and seems to have power until I pull trigger and no wire feed.what do u suggest I do or try?
blow clear the contactor. The 24 volt contactor in the cabinet is either not closing or closing on very dirty contacts.
Jan 16, 2012 | Lincoln Electric Welding Tools
Miller cricket 115 volt wire welder stock #909071. plug it in, it starts feeding wire...even when switch is off. where do i look?
The contactor is stuck closed, the trigger wiring in the cabinet is shorted together or trigger switch stuck closed.
Jan 09, 2012 | Miller Welding Tools
Auto arc 4110 not working
Check wiring diagram to see if it has a bridge rectifier. My 120 had one and it was bad which would not let the feed motor run. It cost me about $6.00 to replace from Ebay.
Jul 06, 2010 | Hobart Handler 140 Mig Welder
I HAVE A HOBART 120 HANDLER WIRE WELDER. THE FAN RUNS AND I HEAR A CLICKING SOUND WHEN I PRESS THE FEED BUTTON ON THE GIUN, BUT THE MOTOR WON'T FEED THE WIRE.IS IT MOST LIKELY THE CONTACTOR IS DEFECTIVE OR...
sounds like the bridge rectifier is bad.to test the motor unplug the motor from unit connect 110 volts to the motor itself and see if the motor runs.easiest way to test motor
Mar 23, 2010 | Welding Tools
Dec 28, 2009 | Miller Welding Tools
Lincoln Electric Mig Welder-Fuse question
dont know what unit your uncle has but here is a easy test,open unit go to feed motor unplg the connector have unit running pull gun trigger check for voltage at plug ,if no voltage trace wires back (with the unit unplug , for your safety)probably will go to one side of main contactor.restart unit being careful for this is main input power.if no power main contactor is bad .if you have power at motor plug(wire feed motor) the motor is bad. hope this helps your uncle.
Jul 11, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Seised wire inside feeding tube
Dec 23, 2008 | Hobart Handler 140 Mig Welder
Welding Tools Logo
54 people viewed this question
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
