Needed for 2 people
4 medium-sized potatoes
1 tablespoon sunflower oil
Spices as desired, such as curry or barbecue herbs
Preparation of potatoes
SOURCE: I used the sharp to bake potatoes and after two
Assuming that the internal cooling fan was working properly, it may be as simple as a failed magnetron thermal cutout.
I don't have an exploded view on this one, and the supplier's part list is not detailed properly, so you would have to remove the magnetron thermal cutout and look for the numbers on it, either 145 or 150.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Then here would be the part numbers:
RTHM-A080WRE0 Thermal Cut Out 145 Degree c
RTHM-A085WRE0 Thermal Cut-out 150'C
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
You should also check the 20A ceramic fuse. Fuses can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
If you need more help, please replay back. Otherwise...
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: air is escaping from the lower oven on the bottom edge.
No, the door gasket is leaking hot air, you're loosing hot cooking air. Check the door gasket.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: My parents have purchased a
yea you can bake sweet potato in it on the pan 30 min. on each side.
