SOURCE: snowblower manual
Not sure if your looking for a parts manual or a user manual but if you go here you can find the parts manual:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=536.885921
SOURCE: need manual for craftsman snowblower 42 or parts below
Ok
That Snowblower is made by Agri- Fab for Sears/Craftsman .If you go online to the agri-Fab website it is possible to down load the manual or if you email them they will send you a copy. I have dealt with them.They have even sent me missing parts. GOOD LUCK
Mike
SOURCE: Craftsman II model 917255911. Will
I couldn't find the manual for your tractor but I did fiind one for a 917255917 model it calls for a 71-25231 snow thrower. The 842 model you listed must not be complete number. There are several different models that start with 842. Does your tractor have the horizontal engine that has clutch on front, and drive pully on rear of engine? I used to have one like that and I had a sears blower on it. You'll need wheel weights and chains too.
SOURCE: I'm trying to attach a
Here is the manual for the snowblower; http://www.odref.com/agri-fab/SnowThrowers/LST42.pdf
You may want to call Agri-Fab at (800) 448-9282 first to make sure your snowblower has the correct brackets to fit the Craftsman tractor.
Have the numbers off the snowblower nameplate and the model number of your tractor (it's under the seat)
