SOURCE: GIVING ELECTRIC SPARK INSIDE THE WASHING MACHINE DURING RUNNING
washing machine motor sparks during spinning
SOURCE: Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load Washer- when
Hello,Most likely this will be the drum bearings.
Bearings normally last
quite a long time but some will fail sooner than others. Quite often
bearing failure is due to a faulty drum shaft seal which allows a small
amount of water through and in to the bearings. The bearings then start
to rust, which then accelerates the wear on the bearings.
Replacing
the bearings needs well above average DIY skills to do, so unless you
feel confident to tackle the job, can get hold of a tech manual, and
can get hold of new bearings, it's time to call an engineer for a quote
and then draw your own conclusions as to whether it's worth it.
Thanks
SOURCE: How do I remove the top panel of the Whirlpool Cabrio washing mac
To gain access to a Cabrio washer, use a putty knife to press inward on the 2 spring clips located where the washer top meets the washer's front/side wrap around case. Standing in front of the washer, measure approximately 3 inches inward from the outside of the case. It helps if you get eye level with the line where the top meets the case and shine a flashlight in the crack. You should be able to see the clips. Press in on both of them and the top should lift.
Testimonial: "Great! That did the trick. Thanks. "
SOURCE: remove whirlpool wtw5300vw2 washing machine timer knob
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^^&^
