Question about Plumbing
I have a drip in my Eurostream lavatory faucet.....GE370140PBV. How to stop drip??
    Top Expert:
  • Plumbing Master
  • 66,253 Answers
CHANGE THE CARTRIDGES
Posted on Oct 29, 2019
6ya staff
SOURCE:
Anonymous
  • 82 Answers
SOURCE: I just installed an american standard faucet
Silly question, but did you turn the shut offs back on after installing? If so, the aerator is probably clogged (the screen on the faucet). Unscrew it and clean it out. Good luck
Posted on Dec 31, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
talla62
SOURCE: leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Posted on Aug 25, 2010
Dplumber
Dplumber
  • 119 Answers
SOURCE: How do I remove handle
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
Posted on Sep 08, 2010
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Posted on Jan 13, 2011
Model GE372073. Is a gasket installed between the drain and the sink?
Do you mean the Eurostream GE372073 two-handle lavatory faucet? If so, you need to place a ring of a silicon, acrylic or latex sealant around the drain opening before placing the threaded drain body into the opening. This is not included with the faucet; look for a kitchen/bath silicon sealant (caulk) at your hardware/ home improvement store. The rubber washer should go on the drain body and get snugged against the underside of the sink as the lock nut is tightened.
To see the installation guide for this faucet, go to http://www.eurostream.ca/product_details.asp?id=GE372073 . The direct link to this manual is http://www.eurostream.ca/products/pdfs/GE372073_im.pdf .
I hope this helps. Because the drain body is plastic, do not use an oil-based plumbers putty when you assemble the drain.
Jul 01, 2018 | Plumbing
Fix eurostream bathroom faucet model# GYE370140
The stem may have to be replaced. Normally, there should be packing or a seal to prevent the drip.
Jun 19, 2017 | Plumbing
Constant slow leak
more than likely hot side that is leaking as hot water tends to soften washer...try shutting off hot water angle stop under faucet...if drip stops it the hot water.. try pulling handle off and tightning nut that hold stem in place..
Nov 21, 2010 | Hansgrohe - Lavatory Faucet - Centerset -...
How do I remove handle of lavatory faucet to replace cartridge? The faucet is dripping and making a noise
Sep 07, 2010 | Price Pfister Treviso Wide Lavatory Faucet...
Peerless faucet P99196 dripping; tried everything. Only made it drip more. How to fix?
If you have replaced boots and springs and or cartridges. Did you replace with after market parts or OEM. If after market parts were used use OEM. Hope this helps.
Apr 11, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
How do I fix a dripping MOEN T4572 lavatory faucet
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
Plumbing Logo
41 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
