I have a smart drum lg.what does IE stand for
It refuses to spin driving me crazy I'm 66 years old and cant stand it
  • Washing Mach... Master
  • 6,073 Answers
IE means inlet error. The washer did not detect the normal amount of water flowing into the machine in the expected time.
If no water enters the drum, check if the shut-off valves were opened. If a small amount of water flows into the washer, check the water pressure to the washer and the inlet hoses and the debris filters in some hoses/washers. (Filters can clog. Anti-flood hoses can limit the water flow through them when they start to fail.) To check this, grab a bucket. Turn off the shut-off valves and take the hoses off the back of the washer. Drain the hoses into the bucket. Check the filter at the inlet valve on the washer. Before replacing the hoses, test the water flow by opening the shut-off valves one at a time. (Turn off the valves and remove the hoses from the shut-off valves. Check for debris in a filter there.) When you replace the hoses, make sure that they are straight and do not have any sharp twists or bends in them. If you hear the water flow and then drain out, make sure that the drain hose isn't positioned below the normal fill level of the washer.
You can also get this message if there is a problem with the pressure switch that determines how much water is in the drum. Frequently the problem is dirt clogging the air tube. This debris might move out of the air tube if you blow into it. Other possible causes are that the inlet valve is not be opening, bad wiring between the pressure switch or inlet valve and the control board or the electronic control board is faulty. Faulty parts will need to be replaced.
Please add a comment with the model number of the LG smart drum, if you'd like me to search for the parts diagram for your unit. If the unit is under warranty, contact LG. I hope this helps.
Posted on Oct 28, 2019
    Top Expert:
  • 30,887 Answers
Hi Penny
I am 66 years old as well and recently retired. All is good in my life :>)
The IE Error is a water supply problem. Can be frozen pipes, but most likely a blockage in the strainers where the supply hoses go into the machine.
Turn off the home's hot and cold water supply taps/valve. Remove the water inlet hoses from the washer. Ensure to have a bucket to drain the remaining water from the hoses. Check the inlet filters on the inlet valves of the washer, inspect for any mineral deposits or other debris that may be clogging them.May 10, 2018
IE Error Code - Front Load Washer ' LG USA Support
https://www.lg.com > support > help-library > ie-error-code-front-load-wash...
5 Suggested Answers
Anonymous
  • 3130 Answers
SOURCE: washer wont spin
sounds like the motor or clutch unit could be the problem I would for sure call in the warrente shop to fix it as if its the motor thats expensive!! good luck
Posted on May 01, 2006
Anonymous
  • 62 Answers
SOURCE: LG WFT1391TP GUZZY LOGIC
Should still be under-warrenty check with your local service agent first please advise if you need any further advise
Posted on Jan 03, 2008
Anonymous
  • 187 Answers
SOURCE: water drains but won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
Posted on May 22, 2009
buffalonyman
buffalonyman
  • 1865 Answers
SOURCE: my dryer will be 3 years old next month and the
If you have to replace the drum in 3 years, then i would imaging another drum will wear out within 3 years. Sounds like garbage to me, I advise replace the dryer. Sell the LG on ebay for parts
Posted on Jun 14, 2009
Anonymous
SOURCE: drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Posted on Jul 03, 2009
On final spin of my 10 year old LG washer we get a loud humming doing from the drum.
If under your washing machine there is a trace from the water (rust, water stains) or just a loud noise then you need to replace the drum bearings.
May 24, 2018 | LG Washing Machines
Machine won't spin...everything else working
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 21, 2010 | LG WM-0532HW Front Load Washer
Our LG Dryer DLG0332W is about 5 years old and now I have to manually turn the barrel around to get the dryer to start; otherwise when you hit the start button it just buzzes and doesn't start. What do...
the dryer has Defective Drum Glides/Rollers.
The dryer drum rests and spins on a set of rollers and/or drum glides. The glides and rollers provide low friction contact points that allow the drum to turn easily. When the glides and rollers become worn they can cause the drum to drag. The dryer might only spin without a load or only when assisted.
Hope this helps.
Aug 07, 2009 | LG Dryers
Drum does not spin
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My dryer will be 3 years old next month and the seam of the drum has come apart and my cloths are getting caught. lg will not stand my their products. the dryer only has a one year warranty no mater what.i...
Jun 14, 2009 | LG DLE5977 Electric Dryer
Uneven Flopping Noise
The drum has a broken weld and needs to be replaced.  Call LG to grant a one time extended warranty to address this issue.  This is a defect problem with their drums.
Mar 17, 2008 | LG DLE5977 Electric Dryer
Dec 12, 2007 | LG WFT1071TP Top Load Washer
Washer wont spin
Apr 29, 2006 | LG WM-1832C Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
