Question about Canon Computers & Internet
Am interested in repair power supply of canon IR 2530. There a switching IC named 2A13708 of 8 legs SMD which I am looking for. Can I have it's datasheet?
    Top Expert:
  • Canon Master
  • 1,994 Answers
This may be the datasheet still looking for other info.
https://www.grenville.com/img/products/pdfs/iR_202530_202525_20Brochure_20(Hi-res).pdf
Posted on Oct 28, 2019
4 Suggested Answers
Anonymous
SOURCE:
lqv77
L? Vinh
  • 6 Answers
SOURCE: i need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Posted on Sep 07, 2009
Anonymous
  • 166 Answers
SOURCE: i need ic used in
man that going to be amouth impossible to find because is more cheap to buy a new power supply for 25 bocks that going to kill your self trying to repair one sorry but good luck
Posted on Oct 24, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: HI ! My name
You will need service manuals at this point, so please try downloading them from here:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1716&kategoria=monitor&kat2=all
I hope they are close enough for the PCB you have.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Posted on Dec 19, 2010
Canon 2525i image runner bringing error E000002. What could be the problem with the machine
Error E000002-0000 on B/W printer. That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine. ... Hit "additional functions" key on the printer's keypad. Canon ir 2520 2525 2530 error e000002 How to solve
Jun 18, 2018 | Canon Office Equipment & Supplies
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | Canon Office Equipment & Supplies
What's the most likely problem with my 50" LG 50LN5100 LED LCD TV. The standby light illuminates when plugged-in but the screen doesn't come on nor is there any sound when the TV is turned on.
Thunderstorm over the coax or /and the power supply measure the power supply by a defect cannot be measured anymore over an analog hand adjustable power Variac transformer from 0 to 240 volt. because a protection can be given by a defect t-con board (as suggestion) but the variac its good to bypass/ overhaul the build-in safety protection circuit inside the power supply board then sometime if there else are broken or bad components hard to find they can be sometimes intentional burning out or become warmer by twist the variac power slowly up from of zero volt until the max necessary voltage T-con boards that can have a problem with smd components sometimes they can burning out the defects but its only to do if there is no equipment to measure repair or nothing was to find without a service manual or other optical defects , an short-circuit tuner also by thunderstorm sometimes only the little ceramic capacitors what hangs to earth (chassis) if the thunder energy was coming over the antenna coax cable. the power supply can stand in a safe protection mode. then a refurbished board somewhere can be necessary that will give a reset to release the protection mode in the power supply.. Thunderstorm can be strange and much different and i have had 2 times repairing when there was only 1 ceramic short-circuit ceramic capacitor to find thats was with one leg is( on cold-earth) on the chassis. as the one and only defect component. A time in a TV and 1 time in a radio , sometimes its realy strange but comes it over the power supply its hard to find because of more recurring complaints if partial repair in smd circuits. hard to do without necessary tools.
Jul 26, 2017 | LG Televison & Video
Error 0099 canon image runner
0099 : SMART PANEL Canon-IR-2520-2525-2530: A memory communication reservation has been cancelled.
Looks like it was answered here for a different printer -
http://www.fixya.com/support/t7156967-canon_ir2020i_dasnt_print_error_code
Sep 09, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Error code E000001 in canon ir 2530
E000-0001: Fixing temperature abnormal rise
Description: The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy:
- Go through the following to clear the error:
CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
- Check connection of the Connectors (Thermistor Connector and AC Connector).
- Replace the Fixing Main Thermistor (Film Unit).
- Replace the Fixing Assembly.
- Replace the DC Controller PCB (PCB4).
See Service Manual page 173 (7-3):
Canon imageRUNNER 2530 Service Manual Page 173
Dec 10, 2013 | Canon 2530 ImageRunner Copier
I have coystar ir 2530 I have error C4200
This error isin referencetoa bad laser unit. The only way around this issue is repair, replacment of that unit will be my recommendation. Do not hard reset this unless you have the new part in. Now while the tech is in there you might want him to check the DC board for issues. A bad laser unit can be the result of a bad dc board.
let me know if you have any more questions rulds2008@gmail.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 12, 2012 | Copystar Ri-2530 Printer
HI ! My name Igor from Saint -Petersburg -Russia ! I have problem with my lcd monitor ACER AL1716F model ! AC 220V voltage is up over normal and my monitor is dead ! I am open ...
Dec 19, 2010 | Acer AL1716 F Monitor
Trransistor by five legs had destroyed i want
That 5-leg component is an IC, more likely to be switch mode power supply IC. What is the make and model of this product? What is this product? Pictures will help a lot.
http://s807.photobucket.com/home/budm/allalbums
Apr 27, 2010 | HP mx705 17" CRT Monitor
Computers & Internet Logo
Top Canon Computers & Internet Experts
old marine
old marine
Davit Mamyan
Davit Mamyan
robert roberts
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
