it sounds like dead cel in one of the batteries, try having batteries loaded tested.
SOURCE: The battery charger does not work. The red light
SEEK AN ELECTRICIAN WITH HIS METER WHEN SOMETHING GOES WRONG WE TEND TO THINK OF THE WORSE THINGS RATHER THAN THE BASICS,IM DISABLED MYSELF,THE BATTERIES ARE TO BE TREATED WITH RESPECT,I DONT KNOW WHAT CHARGER YOU ARE USING BUT PLEASE ONLY USE WHAT IS ADVISED BY MANUFACTURER,NOT ONLY THAT IF YOU DONT YOUR WARRANTY WILL NOT BE VALID.HAVE A NICE DAY COLIN.
SOURCE: I have a jazzy 1121 electric wheel chair. when
make sure your free wheel levers are in the correct position
SOURCE: Just bought sed Jazzy Select for my wife. Chair
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
SOURCE: I have a Jazzy 1113
huntin you might not get a reading at the plug to the batteries because if its not connected to a load the charger might operate until it senses a load. a better way to check would be to plug the charger into the outlet and take your meter set it to 200 volts dc and plug it into the two outter holes of the chager port located under the front of the joystick. you should get 27-30 volts dc with the charger plugged in. when you unplug the charger you will be reading the battery voltage. After charging overnite you should be reading 26-30 volts dc if you aren't getting that voltage replace the batteries Hope this helps
Testimonial: "Thks for the info.It was real helpful in finding the problem with my Jazzy 1113 chair ."
