SOURCE: KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
SOURCE: Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
SOURCE: New dishwasher does not get dishes dry
Check your owner's guide; it may be defaulting to an 'economy' cycle to qualify for 'Energy Saver' status. You may have to choose a less-efficient cycle to enable the heating element for drying. We also open the door slightly to allow moisture to escape. On some units however, it's possible that the interlock will shut the element off if the door is at all open.
SOURCE: condensation in dishwasher
Make sure you aren't selecting the eco setting to conserve power. Running a dishwasher in that mode disables the heating element that dries the dishes at the end of a cycle. Here a few ideas you can try,... with an empty dishwasher.. start a cycle and make sure you do not use that ECO mode if it has that feature.. then stop the dishwasher when it near the end of the cycle and open the door ./.. check to see if the water has been drained and that the heater element is on and hot. If there is a high volume of water in the bottom of the dishwasher, make sure the darin filter screen is clean and not restricting water flow... If that is clean.. and you have a lot of water in the bottom pan, you could have a problem with the pump, a hose in line with the pump or your house drain system is restrictive.. Good luck... and Hope this helps you..
SOURCE: The dishwasher (Dishlex DX302) is not drying the
Have you selected the eco wash cycle.it wont dry on an eco cycle.
