Question about Craftsman Garden
Need to replace pullstring on Craftsman mini tiller
    Top Expert:
  • Craftsman Master
  • 34,143 Answers
If youve never done this before i suggest you take it to a small engine repair shop... shouldnt cost much. call and ask
Posted on Oct 25, 2019
6ya staff
SOURCE:
Joe Hogan
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
Anonymous
SOURCE: pull rope broken on craftsman rototiller
cluch calbe
Posted on May 23, 2009
Anonymous
  • 437 Answers
SOURCE: What type of oil goes in my 4 cycle 26cc mini
regular 30whd just like your lawn mower
Good Day.
Posted on Oct 26, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: I need to know the plug gap on a 31.5cc Craftsman
Set you spark plug gap to twenty five thousands, or the width/thickness of a match book cover if you have no gauge.
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 02, 2010
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: I am replacing all the fuel line including primer
I see that this machine has a 2 stroke engine. These directions work on the 2-stroke engines of Sears trimmers. I've never seen a diagram but many explanations are out there.
The small diameter line out of fuel tank (has fuel filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carburetor. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Oct 22, 2010
How do you change the primer bulb in a craftsman mini tiller?
some primer bulbs come as an assembly and have two clips that snap into the housing others are bolted in with 2 screws if so remove the screws and make sure to take what is left of bulb to match up the new one
Oct 15, 2012 | Craftsman 2-Cycle Mini Tiller
Craftsman mini tiller runs great for a few minutes then revs up a little and then dies. Restarts after a few minutes and then repeats over and over.
Fuel starvation, try slacken the filler cap to rule out a blocked tank vent, if no better replace the fuel filter in the tank, if no better you will have ti remove the carb and clean the filer under the pump diaphram.
May 13, 2012 | Craftsman Gas Mini - Tiller/Edger
I own a 2 cycle mini tiller craftsman and I need a manual for it. I want to tune up tiller it's blowing smoke.
Manuals for many Craftsman tools are available here: http://www.managemylife.com/mmh/owner_manuals . Lots of tillers are listed just by searching for Craftsman tiller. If you can find the model number (usually on a plaque on the housing of the tiller), you can narrow down the list greatly.
I hope this helps.
Mar 31, 2011 | Mtd Craftsman 4Cycle Mini Tiller
I bought the Craftsman 4-Cycle Mini Tiller , Model# 29937 at Sears this morning. It did not has a manual. How can I get the manual ? Thanks Le
Your situation is puzzling and in fact on the Sears site with your tillers' parts list, they state the manual is no longer available with no replacement either. See item no. 92 on parts list.
Here is the parts list and diagram if there are any help to you.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/All-Products-Parts/Model-917299370/0247/1508000/00010290/00001?blt=06&prst=&shdMod=
Don't fear. Here is a link to a 6.5HP Craftsman tiller that I also hope will help. This model is a close relative but has rear tines.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0912306.pdf
Oct 21, 2010 | Craftsman Gas Mini - Tiller/Edger
I have a Model 29270 REV B00 Craftsman 4 cycle mini-tiller. Can't find a spark plug or air filter. Appreciate some direction.
Craftsman part numbers will help on this search. Typically 3 digits separated by a '.' such as 345.45687
If you can find these, please re-post the question. :)
Sep 25, 2010 | Craftsman Gas Mini - Tiller/Edger
Craftsman mini tiller. Are you selling this unit, giving it away or what. Your information is somewhat meager to say the least.
May 28, 2010 | Craftsman Gas Mini - Tiller/Edger
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
