Recycles, dumps and refills okay. Switch on front clicks but motor doesn't activate to dispense ice. Water dispenses just fine.
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
SOURCE: Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact. http://fixitnow.com/sbrvrs/icemakers.htm
SOURCE: ice dispenser not dispensing ice or water
The tube that supplies water to the tray of the ice maker,may have frozen solid. unclog u should be good
