SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
SOURCE: 2001 sonoma parking brake petal wont lock into place
There's a ratchet in the top of the pedal which holds the pedal down when depressed. This ratchet is worn, broken, loose, or it just needs lubricating. I would first try WD-40 on the top of the pedal where it attaches to the frame/chassis.
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
