SOURCE: HP Deskjet printer suddenly stopped printing wps files.
Just installed iolo System Mechanic; it probably confilected with my PC Doctor program, causing the problem, now I am unable to uninstall HP 812c programing to reinstall.
SOURCE: my hp 1200 printer is not printing dark enough.
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
SOURCE: HP Officejet Pro L7780 Prints photos too dark
try to do flee power cycle of the computer and then try to uninstall and reinstall the driver for the printer.
IF IT DOESNT WORK .LOG ON TO THIS LINK
http://techbuddies.org
