How to remove front panel for ice and water on my GE GFE27GGDA
It the ice water and crushed ice touch buttons. Fare left one for water seems stuck. I pretty mechanical and would like to know how to remove this front panel. Louie...
Turn off icemaker. Remove ice bin, empty it, rinse with warm water and leave to dry overnight. If this did not help - check solenoid in the freezer behind the ice bin, make sure it's not stuck and has continuity. If all checked out ok, but still no cubed ice - control board or interface board may need replacement, and you'll need a professional to diagnose that.
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
try taking off the dispenser front and check the "switch " controlling water /ice. its a micro switch your connecting with as you change from one to the other{ice to water) im assuming that the switch is not being activated. plungers get stuck switch gets old
