If the circuit board is damaged, you can contact the manufacturer and possibly get a new circuit board. It would be good news if it were under warranty --maybe.
Immediately after immersion and retrieving it, one might try blow drying it (or drying it with a heater). But you can't let it sit around and dry on its own. Chances are, you are fated to get another drill.
SOURCE: When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
SOURCE: I have a cordless 14.4 Milwaukee Driver/Drill that
You can have this rebuilt at any milwaukee service center for about 50 bucks, half the price of a new one.
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
SOURCE: Variable speed doesn't work on Milwaukee Magnum hammer drill
how new is the tool. Give me the serial number and I will come up with a solution, also what is the switch number you bought. Let me know.
SOURCE: Slipping clutch on low switch with Milwaukee 2601-20
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
