SOURCE: I need a Manuel for
go to this url...
http://tasco.com/support.cfm
under riflescopes look for propoint red dot and then save the pdf file to your computer or you can print it.
SOURCE: Where do I get a eye lens for Redhead outlook
Find an Optics outlet that deals in this brand. Or a very good optics person will be able to fix it regardless.
SOURCE: how to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail
mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10
IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
