Question about Craftsman Garden
Craftsman Tractor 917.28970 power belt and replacements keep falling off. It's 95 in long but has way to much slack.
    Top Expert:
  • Craftsman Master
  • 22,486 Answers
Wrong belt or routing it wrong
Posted on Oct 20, 2019
6ya staff
SOURCE:
Anonymous
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Dwain Pippen
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: How to replace drive belt craftsman tractor
There is a video on YouTube that may help you somewhat with the belt replacement. You may want to check it out. Here is the link. Sure hope this helps and best wishes.
http://www.youtube.com/results?search_query=lawn+mower+belt+replacement&search_type=&aq=1&oq=lawn+mower+be
Posted on Aug 25, 2009
Testimonial: "Good, quick feedback - thanks --"
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Posted on Aug 31, 2009
lonewolf1996
Lincoln Brunell
  • 142 Answers
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
Posted on Sep 02, 2009
How do I get the lever to shift to lift the mower so that I can replace the belt? 19hp, 42", year unknown craftsman turbo
If it is the drive belt do the following place your mower on a level surface set parking brake, remove mower deck, remove belt from stationary idler and clutch idler, pull belt slack towards the rear of tractor , then remove belt upwards from transaxle pulley by deflecting the belt keepers, then pull the belt towards the front of mower and remove downwards from engine pulley Install new belt in reverse procedure
Jan 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What size hydro drive belt can I use to replace the craftsman belt, part# 140218??
The Craftsman drive belt #140218 is a 1/2" by 84.3" belt with an aramid fiber wrap.
Since this belt is contacted on both sides (inside and outside) as it runs the pattern on your mower, it must be replaced with another belt of exact size and construction. If you were to use an 84" belt, then the tension pulley would not have enough slack to disengage the transmission. Likewise, an 85" belt would have too much slack and cause the trans to slip.
The original belt is available through www.searspartsdirect.com for about $25 plus shipping. Check with your local lawnmower repair shop, they probably stock this belt and will be competitive in price.
Oct 29, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
The deck belt keeps falling off of my Troy-Bilt 14AT809H766 Horse riding lawn mower. Why? How do I fix it?
Either the belt is stretched out and needs to be replaced or there is an idler/tensioner pulley that may be weak and not putting enough pressure on the belt.
Jun 30, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
How do I replace the Drive Belt on a Craftsman riding lawn tractor Model # 917257643 15 H/P OHV I/C Gold
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drive belt keep falling off
you have belt guides near your pulleys that helps to keep the belt on during no engagement
you need to check to see if they are missing or bent and adjust as close to the pulley and belt as possible without interfereing with the belt and pulleys while engaged.IE: no rubbing against the pulley or belt while engaged or moving.
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
