Question about Craftsman Garden
How do I change the head off a craftsman weedwacker Mdl: 316.711023
6ya staff
SOURCE:
Anonymous
SOURCE: Craftsman Hassle Free head Electric weedwacker manual
How do I pop the lid off? I usually take it somewhere to have it done. Please help...
Posted on Aug 31, 2008
digritz
david mcclellan
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: Weedwacker won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 02, 2010
Testimonial: "Wonderful response that I will follow-up on. Also, very quick, and complete"
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: How do you change a craftsman 32cc weedwacker gas
Hi davemac918...
I used a long pair of tweesers to grab the filter, but you can also grab it with a piece of wire with a hook bent on the end of it large enough to fit the tubing the filter is inserted into.
Hook the filter tubing, and pull the filter to the top of the tank and manuver it out of the tank.
Please take time to rate me
Posted on Sep 11, 2011
JAL69692002
JAMES LAND
  • 334 Answers
SOURCE: my 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Posted on Nov 15, 2011
While trimming a type of brush wrapped around the cutting head and made the unit stall, upon clearing it the head now is weak and does not spin with enough power to cut; how can i fix this?
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below
Craftsman 17 25cc Weedwacker
Sep 15, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Not sure what you mean but if you are saying the weedwacker head is not engaging it may be the cable that goes from the motor to the weedwacker head and runs down the inside of the shaft.
May 24, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
Weedwacker overheats
air leak around crankshaft, scrap it and buy a new Stihl.
May 23, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
How do I remove line head to so as to fit a pivotrim head on a 31cc 17" craftsman weedwacker
The best solution is to get the owners manual so you have complete information. Go to www.searspartsdirect.com and have your model number ready.
Jul 29, 2011 | Craftsman 25cc Gas Line Trimmer
How do I thread my Craftsman weedwacker?
How do I Re Tread my Craftsman 13"
4.0 amp electric weedwacker line trimmer?
May 29, 2010 | Craftsman 27cc 2Cycle Full Crank Curved...
Garden Logo
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
