Question about Bosch Washing Machines
My Bosch WET 2820 washing & drier machine stopped working while there was still 2 min to finish drying clothes
I had to unplug from energy for few minutes to open the doors and take the clothes out. When I turn the equipment again it remains with pending 2 min to dry and nothing else works. The machine simply is not working!
6ya staff
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: a problem with my Bosch washing machine
It usually takes 2 minutes after the wash to open the door; do not force the door. Doesn't matter if the active light is on. Just try.
Posted on Oct 05, 2007
Richard Lew
  • 489 Answers
SOURCE: Unit will not turn on at all
Sounds like the problem is with the control board.  There is an internal fuse in the board but it is not replaceable.  You will need a qualified LG technician to service this unit.
Posted on Apr 28, 2008
Roger Miller
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Washer works fine, but clothes no longer dry.
Hi Ron,
Having at one time done warranty service on those machines in a decent size city ( Calgary Ab. Canada ), I saw these almost daily so I know exactly what is preventing the clothes from drying ( 99% sure at least )...even though as you`ve stated "feel heat around the machine". The condensor fan wheel and heater housing are clogged with lint.
**turn off the power or unplug the "combo" from the wall**
If you are capable of removing the top you'll soon notice there is not much elbow room in there to work...even less than home units which are a little easier, but not much. Fortunately for this issue you won't need much. On top, directly behind the timer on the right hand side top of the tub, is a "condensor/heater housing" ( usually made of "white metal" or "pot metal" as some refer to it ) with a blower fan motor fastened to the top. Remove the fan motor wires and then the motor itself from the housing via four hex head screws ( they may be philips heads...that`s not important ) around the perimeter of the fan motor bracket.
This is where "elbow room" may be tight, but with persistence and careful maneuvering you can do it. You may be able to move the tub to the back and left While backing out the fastener's/screws to give you a little more room. Pull the motor assembly up & out ( careful of wires and sharp edges ) and examine the blower wheel and housing. By now it should be obvious of the problem. These unit's because they are so compact are vulnerable to lint build up in the blower wheel and housing hence, the unit will not perform well in the "dry" cycle.
When you have the blower removed I find running hot water from the sink tap ( or anywhere...I don't think it matters, ha ha ! ) over the blower wheel cleans it thoroughly. Cleaning out the condensor housing is a nother matter...by hand is one way to do it. It can be cleaned via a garden house, but be careful not to overfill the tub or flood your place. ( if possible, take the washer right out of the RV/motor home ) Normally it drains when plugged in, but since your's is not plugged in it will have to drain with gravity, that`s why it`s good to remove the entire machine from indoors. Hope that helps move you forward, or better yet solves the problem entirely. Let me know if I can assist you further, I'll watch for your reply here. Thank's for visiting "fixya" for your repair inquiries. Good luck, Macmarkus :)
Posted on Apr 14, 2010
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Bosch WVD24520GB washer dryer runs a wash fine but
If your dryer is a condenser type maybe you need to yank out the condenser and give it a good clean. Could not make the model number posted work.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 21, 2010
Machine is locked
Have you tried simply unplugging the machine - that is if you can get to the plug. Or, you could always flip the circuit breaker off. Either way, leave it off for a minute or two, and that should give it time to forget what it was doing. Once you start it back up, it should unlock, unless it has some kind of static memory that survives power outages.
Aug 12, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Awz 412 washing machine/dryer.
With a washer and drier thay do , a separate drier would be better for you
Dec 13, 2017 | Whirlpool Washing Machines
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Washing Machines Logo
53 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
