Televison & Video Logo
Daniel A Posted on Oct 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 50uh5500 4k smart TV. Why doesn't it turn on?
The power supply board is L5L01F / COV33697901. When the tv gets plugged in, the power light just blinks red 3 times. If it gets fully discharged first, the screen flashes on for a second just long enough to see the LG symbol pop up and then shuts off and the power light blinks 3 times. I didn't notice any leaking/bloating on the board. I tried disconnecting the main board and powering it on but the LEDs don't come on at all. I've repaired electronics in the past by swapping out bad parts but this is my first time attempting work on a circuit board. I just got my first digital multi-meter yesterday. Assuming I'm using it correctly, the voltage to the main board is ~3v low supposed to be 13.5v according to the power supply board and also, one of the -led prongs reads lower than the other 2 led2- reads lower than led1- and led3- but I don't know what the voltage is supposed to read.
Tom Chichester
Level 3:
Top Expert:
  • LG Master 62,329 Answers
  • Posted on Jan 02, 2021
Tom Chichester
LG Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672049
Points
975369
1. Open internal fuse
2. Power supply failure
5 Related Answers
Anonymous
  • 138 Answers
  • Posted on Aug 19, 2008
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Anonymous
  • 10 Answers
  • Posted on Aug 18, 2009
SOURCE: led light flashes thre times
I would initially suspect IC7001 and/or IC7002 on the D board. Those are your convergence output IC's. Those tend to fail after 5-10 years of typical use. Part# STK392-150 is available as a direct drop-in replacement part and repeat failures are almost unheard of. Also, check the low-ohm feedback resistors around these chips. R7011, 7012, 7013, 7014, 7015 and R7016 should all be 2.2 ohms @ 2 watts. If you have a shop do this, the typical price including travel and house call is $300-400. Parts alone are about $50, give or take.
Anonymous
  • 10594 Answers
  • Posted on Aug 12, 2011
SOURCE: When plugged in, Sony Bravia
Check BL_ERR pin on back light inverter board, what is volt reading that you get before and after tv shuts down? Let me know to proceed.
Thanks.
BTW, I really enjoyed your quote * I don't trust the blinking anymore *
gopakumarg43
  • 76851 Answers
  • Posted on Sep 24, 2011
SOURCE: Dynex DX-PDP42-09 Won't power up.
Hello
The main board is faulty. This is the common problem to most of the dynex TVs. As you know there is no repair to this board. Replace it as card basis is the only remedy to this fault.
gopakumarg43_84.jpg Replace this board, rather than making surgery to it and wasting your precious time and money. The cost of the board come around $95. OK.
Brian Carson
  • Posted on Jan 29, 2014
SOURCE: LG Washer wont start, no power
I HAVE A BEKO 42WLH530HID TV, AND WHEN I TURN IT ON THE STANDBY LIGHT COMES ON BUT NO PICTURE OR SOUND, I KNOW ITS 1, OFF 3 CIRCUT BOARDS BUT DON,T KNOW WHICH ONE, CAN ANYONE HELP ?
Replaced power board on Samsung smart tv, still not turning on. could it be a main board failure?
1. Make sure the back lights are OK, to do so, unplug the cable between the power supply & the main board, apply the AC power to the power supply, if the back lights are OK, it should light up.
2. If the back lights are OK, i will try a new main board first.
My vizio smart tv model number E601i-A3E has no power at all to it.
Measure the voltages coming from the power supply and see if you have your standby voltage, if its missing then change the power board if its missing change the main
2answers
Vizio m55-c2 55-inch 4k ultra hd smart led tv fixing won't turn on
Your done, replace the TV before you bury yourself in parts cost and labor.
Getting fadded black horizonal patch at the top of my Toshiba Smart TV. 50L3400U How can I fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Whats wrong with my TV ? I have a vizio 60 inch smart tv. When I turn on the TV the screen is blank. I do have sound and the screen does glow. Something is wrong with the backlight. How do I fix it?
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Tv has power in stand by mode but no power or blue led light when trying to turn on. it seems the tv has no power
Unplug the T.V. and hold the power button down for 30-60 seconds. Plug the T.V. back in and try powering on. If it still doesn't power on then you may need a firmware update, or something on the board has gone bad such as the power supply or capacitors. You can take off the back of the T.V. and look for any swollen capacitors on the board and see if the power supply looks ok.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
