Washing Machines Logo
W
William Eisler Posted on Oct 15, 2019
Where is the drain filter clean out on model gcvh6260HWW GE clothes washer?
inspirationp
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Oct 18, 2019
inspirationp
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
12923
Points
70
5 Related Answers
Anonymous
  • 66 Answers
  • Posted on Sep 14, 2007
SOURCE: Water won't drain
make sure there is power getting to the pump if so then your pump has stopped working or may be blocked if not than it will most likly be your pcb
johnychel
isaac johny
  • 796 Answers
  • Posted on Mar 23, 2008
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Anonymous
  • Posted on Mar 01, 2009
SOURCE: my ge front loader washer will not drain
We had same problem. The pump was all clogged up with fabric debris, and a part of a metal bra liner. I removed the pump and cleaned it out. Now it seems to work fine, and went through a complete cycle. Ther pump was accessed from the front, and was not too hard to remove.
Anonymous
  • 187 Answers
  • Posted on May 21, 2009
SOURCE: Clothes come out of washer dripping wet.
Hi
Try this out:
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate my suggestion...
Anonymous
  • 15935 Answers
  • Posted on Sep 18, 2010
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
2helpful
GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
2helpful
2answers
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
GE front load washer (clothes)
DOES NOT SOUND PROFESSIONAL TO ME,ALSO REMEMBER IF TUBE WILL NOT DRAIN SOMETIMES THE WATER PUMP GETS CLOGGED OR SOMETIMES THE DOOR SWITCH FAILS,I HOPE YOUR SHOULDER FEELS BETTER,TAKE IT SLOW AND EASY THE NEXT TIME YOU DO IT-MIKE
2answers
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
3answers
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
2answers
Off balance???
Try to see if there is any block in the hose coming down from the tub to the filter
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
