Televison & Video Logo
J
Jennifer Freeman Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TCL lED tv is powering on/off but no screen. I did a flashlight test and saw a dim menu come up.
I know its not the main board as I already replaced. I believe its the led strips but am not a tv repair pro.
Franco Dosil
Level 3:
Top Expert:
  • Televison & ... Master 10,542 Answers
  • Posted on Oct 15, 2019
Franco Dosil
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379029
Points
178965
Hi Jennifer Freeman, for what you say, your TLC TV, the backlight is wrong, one or more LEDs have burned, so the LCD panel does not light up
To make a correct repair, you must change all the LED strips, so that the same fault does not happen again in a short time
If you do not have technical knowledge to disassemble, I recommend you look for a specialized technical service
I hope you can solve the problem
Regards Franco Dosil
Hola Jennifer Freeman, por lo que comentas, tu TV TLC, tiene mal la iluminacion trasera, uno o mas LEDs se han quemado, por eso no se ilumina el panel LCD
Para hacer una correcta reparacion, deberas cambiar la totalidad de las tiras de LEDs, para que no vuelva a ocurrir la misma falla en poco tiempo
Si no tienes conocimientos tecnicos como para hacer el desmontaje , te recomiendo busques un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
Shokat Ali
Level 1:
New Friend:
  • Contributor 6 Answers
Shokat Ali
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
8345
Points
10
It's not led problem it's got to do with either the mainboard or power board. Its complicated as it needs to be stripped apart and each power source will be checked and visible damage of capacitors so it will require safe handling as electricity in TVs can be very dangerous.
Larry
Level 3:
  • Televison & ... Master 5,042 Answers
Larry
Level 3:
Answers
5042
Questions
Helped
1241629
Points
18413
More bad LED backlights
5 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Feb 05, 2015
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
gopakumarg43
  • 76851 Answers
  • Posted on Aug 26, 2016
SOURCE: Samsung un39fh5000 shutdown no led start has info on screen usung a flashlight replaced both main and power supply bds chked led strips no burning visiable ohms reads high no short im stumped
T'Con board fault. With most modern models of Samsung LCD sets, this board is a built in part of the display panel. If it is a separate part (in case of your set); replace it. Check it out.
If it is a built in part with the display panel, there is no repair other than replacing the display panel.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 04, 2016
SOURCE: Hitachi le49a509 led tv black screen. I can see the menu screen with a flashlight test. There's 3 boards in the back. Tcon, power supply and main board. Which is the problem?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 13, 2017
SOURCE:
Give it up and just replace the TV.
richie46
  • 12962 Answers
  • Posted on Sep 13, 2017
SOURCE:
If it passes the flashlight test then you need a
t con board. TV Parts Universal TV Stands DLP Chips ShopJimmy
My vizio tv has sound but no picture and already did the flashlight test
If your Vizio TV has sound but no picture, and you have already done the flashlight test, it may indicate that your TV's backlight or power supply is malfunctioning. Here are some steps you can follow to troubleshoot the issue:
  1. Check the cables: Make sure that all cables are properly connected between the TV and any devices you are using, such as a cable box or DVD player.
  2. Check the input source: Ensure that the TV is set to the correct input source that the device is connected to. You can cycle through the input sources using the input button on your TV remote.
  3. Power cycle the TV: Turn off your TV and unplug it from the power outlet for at least 1 minute, then plug it back in and turn it on again. This can sometimes resolve issues related to the TV's power supply.
  4. Reset the TV: Try resetting the TV to its default settings. You can find this option in the TV's menu settings.
  5. Contact support: If none of the above steps resolve the issue, it may indicate a hardware problem with the TV's backlight or power supply. In this case, you should contact Vizio support or a qualified technician for further assistance.
Help Troubleshooting TCL R635 6 Series That Stopped Working
Hello, the noise was an LED exploding in the screen taking out the back lights (unfortunately a very common issue) and then the set won't power up. Replacing the is very difficult on that large of a screen without breaking it. Thanks Techman 57
I have a TCL 55S431 TV. All of the backlight LEDs are working, but the screen is dim. Should I replace the LED driver board, the main board, or both?
This model doesn't have a LED driver board so that one is off the table. Where is your backlight setting at?
1helpful
2answers
1helpful
2answers
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
2answers
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Samsung UN40F6300 tv has no backlight. Passes flashlight test. already replaced main power supply board. Is there something I am missing?
Some time the LED back lights can become faulty. If o you have to replace the panel. Because the LED back lights comes along with the panel.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
32" Samsung LED TV repair. Sound but no video
check any wire. maybe one of you wiring are burnt
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
