I am also looking for catalog of sears parts to the craftsman tractor 917.252631 with specification and description of its parts.
SOURCE: How to replace drive belt craftsman tractor
There is a video on YouTube that may help you somewhat with the belt replacement. You may want to check it out. Here is the link. Sure hope this helps and best wishes.
http://www.youtube.com/results?search_query=lawn+mower+belt+replacement&search_type=&aq=1&oq=lawn+mower+be
Testimonial: "Good, quick feedback - thanks --"
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
SOURCE: drive belt 42" craftsman tractor model #917.270810
You need to post the 917.xxxxxx model number for some one to help you. There are about 10 different belts that fit different 42" Craftsman mowers.
You could also go to www3,sears.com and put in the same 917.xxxxxx model number and look up the part number. You do not want to buy a belt just by the size alone but must use one that is made for the machine application. The cheaper ones that you pick up in the local hardware store etc. like a 3Lxxx or 4Lxxx are made for low horsepower electric motors and will not last on your lawnmower.
SOURCE: How to install Mower blade
Hi donsig245,
What I do is to drop the mower assembly to the ground, then I have enough room to install the drive belt without having to remove the mower assembly. You could put the tractor on blocks to lift it up higher so the mower might go a little lower, but it is the same procedure to install the belt. That is the only way I know to install the belt without removing the mower assembly. I know this is not what you wanted to hear, maybe somebody might have another idea that would help you. Regards and good luck.
SOURCE: what size belt for a craftsman lawn tractor model # 247.288810
look it up on sears parts online
