Question about Garden
Why is the pull cord hard to pull - Garden
    Top Expert:
  • Garden Master
  • 64,733 Answers
REMOVE SPARK PLUG AND SEE IF IT HAS FILLED CYLINDER WITH GAS
Posted on Oct 13, 2019
6ya staff
SOURCE:
Husqvarna hedge trimmer hard to pull cord
check the piston inside the cylinder for extreme wear. If it feels sticky and is hard to pull it sounds like a lack of oil in the cylinder and it has started to seize.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 02, 2013 | Husqvarna 28cc Gas Line Trimmer
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
How do I get the hard drive out
1 Unplug the computer. As a safety precaution the hard drive removal should not be attempted while the computer is still plugged into the house current.
2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
4 Remove the metal housing. This should be as simple as removing a few screws.
5
Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQCfJhS
  • Step 6 Unscrew anything that is still holding the hard drive in place and then pull the hard drive unit out of the computer. Now you can externally hook the hard drive to another computer to double check the data base. For this you will need an external holder, which you can purchase for $25 to $50 at your local computer store. Or you can add the hard drive unit to the inside of another computer tower.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ9MXYe
  • Step 5 Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ5WTOQ
  • Step 4 Remove the metal housing. This should be as simple as removing a few screws.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ1AnQp
  • Step 3 Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPuIEwv
  • Step 2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPnVKmo
    Jun 14, 2010 | Sony VAIO PCV-V200G PC Desktop
    When i pull the starter cord it pulls back really hard
    pull off the spark plug and spray wd40 wait 15 min to 30 min and then pull without spark plug in then put the spark plug back in and then try it
    Apr 15, 2010 | Craftsman 8.50 Torque Rating Dual...
    Pull cord getting stuck
    Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
    Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
    Generator hard to start. Kick back
    This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
    May 19, 2009 | Electrical Supplies
    Starter cord only pulls 1 foot
    Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
    Apr 12, 2009 | Garden
    Garden Logo
    Top Garden Experts
    roeb
    john h
    Marvin
    Marvin
