Novotronic W310 is leaking from the bottom, what could be the problem. The pipes seem to be dry
    Top Expert:
  • Washing Mach... Master
  • 54,386 Answers
Leaky pump
Posted on Oct 14, 2019
6ya staff
SOURCE:
Anonymous
  • 185 Answers
SOURCE: Leaking Water
if there is a clamp on there try tightening it up or put a new clamp on it
Posted on Mar 25, 2008
Anonymous
  • 4 Answers
SOURCE: leak
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed.
Posted on Apr 24, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Novotronic 7644C - The dryer is not completely
Have you dumped the water ? I think this dryer is a condenser dryer ain't it? Non vented type dryer? If so there is a water jacket that has to be dumped ever so often.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 17, 2009
arikrom
911 SERVICE TODAY
  • 528 Answers
SOURCE: how do I check the filter
the filter is on the bottom left side in the front panel
also the drain pump is there.
Posted on Jan 06, 2010
Anonymous
  • 185 Answers
SOURCE: water leaking
The drain is lined up with the tray then the heat from frig evaporates it. Use flashlight to see if the drain hose is in lines with tray so it will hold the excess defrosted water. This is a little tricky cause you might not be able to tell untill it is actually dripping so show patience. thanks
Posted on Mar 28, 2010
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Miele Novotronic w310 washing machine - won't spin and flash 'rinse' on the display?
Did you try to set the temperature to the minimum?
Maybe the heating element is faulty....
Nov 30, 2015 | Miele Washing Machines
How do I check the filter on a Meile Novotronic W310
Dec 24, 2009 | Miele W310 Front Load Washer
Therm-x-trol st-12 leaking
Never seen one leak other from the seam or the top or bottom.
Mar 14, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Miele Novotronic Premier Plus - no water into the machine
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Feb 26, 2009 | Miele Novotronic Premier 500 Front Load...
Leaking Water
Mar 25, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
