Question about Hoover Washing Machines
How to remove agitator hoover wash machine 550 MA
6ya staff
SOURCE:
Anonymous
SOURCE: Hoover 550 MA Top Loading Washing Machine
I have 550 Hoover about 6 years old,just out of warranty period,
is currently noticed the problem of stopping during prewash rinse, start again it startsup but stopped immediately.And keep repeating it. If i skip to spin manually then it almost completes the cycle. THis problem starts few months back also then vanished by itself and now it starts again.can some guru tell me if its because of belt or drive belt etc.
Posted on Apr 28, 2008
Anonymous
SOURCE: hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
Posted on Aug 20, 2008
Anonymous
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
firstfix1
  • 69 Answers
SOURCE: How do I remove the agitator in a Hoover 500MD
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Posted on Aug 25, 2009
drallim
  • 4088 Answers
SOURCE: I have a Hoover 550 MB Top Loader washing machine
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Posted on Oct 20, 2009
Testimonial: "That is great advice . Will try and see if your solution works . cheers"
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
How do I remove the agitator from my Hoover 201M washing machine. It really needs to be cleaned under there with all the muck thats building up. Thanks.
if it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
Feb 07, 2016 | Hoover Washing Machines
How do I remove agitator on a top loader Hoover 600mb washing machine?
remove the bolt in the centre of the agitator, usually a 10mm socket and extensions to do it and pull out
Sep 06, 2015 | Hoover Washing Machines
How do I remove the agitator in a Hoover 500MD machine?
Aug 25, 2009 | Washing Machines
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Hoover 800 washing machine
Aug 18, 2008 | Hoover HTC243 Top Load Washer
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
How do I replace a drum paddle in my Hoover washing machine HSWF167
there should be a plug on the top of the agitator. pry off this cap with a screwdriver. you will see the hex nut that fastens the agitator. remove the hex nut and lift the agitator from the transmission shaft. Installation is the reverse of removal.
Mar 17, 2008 | Washing Machines
Need to remove agitator on my hoover 500m washing machine
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
Mar 12, 2008 | Hoover Washing Machines
Washing Machines Logo
41 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
