Question about Microwave Ovens
Cup with water blew inside microwave and door opened. Now microwave not turning on
    Top Expert:
  • Microwave Ovens Master
  • 64,733 Answers
CALL LOCAL REPAIR SERVICE OR BUY A NEW ONE
Posted on Oct 12, 2019
  • Xolani Oct 12, 2019
    Wow what a solution thanks anyway
  • ray gallant
    ray gallant Oct 12, 2019
    THERE IS NO SOLUTION WE KNOW OF
6ya staff
SOURCE:
Earnest Bowes
  • 234 Answers
SOURCE: no heating or power to microwave oven
You have a fuse in the back that's problem is blown
Posted on Mar 13, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: Whirlpool Microwave, No Power
could be a damaged door saftey
Posted on Jun 14, 2009
Flurg
SOURCE: Panasonic microwave oven nns952wf runs when door is open
yep going through the same thing myself. I found that the OMRON switch V-16G-3C25-M is bad and now I'm trying to find one. I contacter OMRON but they said the switch can only be orded from panasonic so I'm going that route myself. If I have any luck I will write back.
Posted on Jul 22, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Inside Microwave is Hot
Hi, What you noticed is perfectly normal...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 29, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Was heating water in a Sharp Carousel Microwave
heatman101
sghg
Posted on Sep 30, 2010
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
Why microwave won't stop running unless door is open ?
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 16, 2014 | Whirlpool Microwave Ovens
Microwave turns on when the door is open must un-plug to shut off
Is it actually heating or just making noise and acting like it's heating? (Put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is that one of the door switches is not working right (it's either stuck open or stuck closed).
Aug 15, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Microwave oven only operates if the door is held closed
    If the microwave oven operates with the door open it is a serious issue. DO NOT OPERATE IT. Call a technician immediately. The RF frequency is extremely dangerous. the safety switches inside the oven are malfunctioning and needs to be replaced
    Jul 03, 2009 | Microwave Ovens
    I need to replace my maytag mmv5000 microwave door assembly
    Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
    Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    Sep 18, 2008 | Maytag MMV5000 Microwave Oven
    Ge microwave
    try to hold the door closed when you first start it set the timer for 1 min with a cup of water inside press start and then hold the door in if it reuns your door is out of aligment or the interlock switch is popping open
    Jan 24, 2008 | GE XL1800 1100 Watts Microwave Oven
    Whirlpool microwave oven
    The magnetron are short need to replace / look for the old or in junk shop magnetron same serial # and etc
    Jan 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    44 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
