Question about Hisense Televison & Video
My hisense tv input button wont work and volume down button want work either can u help
    Top Expert:
  • Hisense Master
  • 54,386 Answers
The remote control may have failed.
Posted on Oct 12, 2019
6ya staff
SOURCE:
techman
Larry Dillon
  • 3130 Answers
SOURCE: Buttons on TV or remote not working. Can only cycle through video input options.
It sounds as though the TVs in a demo mode. Has someone recently been over and was playing with the remote. If so go into the menu of the tV set and look for set up and demo mode. Turn off the demo mode. if this doesent help call i-866-427-3946 and talk to the customer service deptartment. Good Luck
Posted on Aug 09, 2006
Anonymous
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
Anonymous
SOURCE: Lock initiated by Zenith ZN110 Hisense L2020
Unfortunately this happened to me also. I have searched the web to no avail and finally contacted Hisense. They have outsourced their customer service to India (yay!). Upon contacting their customer service, they recommended a solution of unplugging the TV for 30 minutes which did not help - we left it unplugged overnight and still nothing. I think the only solution is to pay the $25 for the rmeote control. Anyone reading this...please do not buy a Hisense product...they are literally poopie in a box!
Posted on Oct 06, 2007
Paul
  • 224 Answers
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
salsaurbana
Luis Rondon
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Hisense tv factory reset :
To do a factory reset; you should enter its service mode option. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Service mod entry, adjust and exit procedure to many popular brand TVs are given in detail.
Jan 23, 2014 | Televison & Video
Wont change input
sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
Feb 07, 2012 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
How do u change av on tv withoute remote
Directly on the TV there should be a button marked AV/Source/Input. That would be the button to press till you reach the desired input.
Thanks
Dustin
Jan 04, 2011 | Hisense Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Unable to play DVD's
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Mar 19, 2010 | Hisense LHD3204US 32 in. LCD HDTV
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Hisense tv on "lock"
If you have the original remote with the "CCL" Child Lock it unlocks it. If you are like me and lost the remote I unlocked mine by 1. Turn on TV 2. Hold down the menu button and unplu it. 3. Continue to hold the menu button down while you plug it back in. Mine unlocked, good luck.
Paula
Sep 06, 2008 | Hisense Televison & Video
INPUT GOING CRAZY
Aug 04, 2008 | Hisense TL-3220 Television
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
