Wascomat washer w185 error code 08 - Washing Machines
4 Suggested Answers
6ya staff
SOURCE:
harkirpal
SOURCE: what is meaning of error motor shortening in wascomat washer
change the inverter
Posted on Jan 22, 2011
The_UG
  • 74 Answers
SOURCE: wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
Posted on Feb 06, 2014
terryskelly
Terry
  • 10445 Answers
SOURCE: have a wascomat w662co washer. displaying error code 054/ no set signal. need help
Wascomat EX618 Service Manual Page 136
Page 136 - Unfortunately, it suggests it may be necessary to change the CPU
Posted on Feb 10, 2018
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
Wascomat w655s what is error code E13 ?
www.teetersproducts.com/.../Used%20Equipment/.../Wascomat%20-%20...
Jul 13, 2014 | Wascomat Parts Wascomat 973957 Washer...
Water is draining while entering machine
Something is holding your drain open Take the dump valve off and check for bra wires.
Jun 16, 2014 | Wascomat Parts Wascomat 002801 Washer...
Wascomat dryer error codes
Feb 06, 2014 | Dryers
Got a exsm680cl washer and it reads error drain not draining
Check the leveling of the machine, if not use a spirit level and use rubber sheets to keep it firm. If the drain hose is detached the water must freely flow out in this case. If not adjust the slope.
Also check the drain pump to open and work with good action. If not you need to remove and clean the filter and reset the pump
Jan 21, 2013 | Wascomat Parts Wascomat 432 251902 Washer...
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
