Question about LG Televison & Video
LG LED Smart TV model 42LB5800-UG won't turn on but red light flashes 3 times then off
  • LG Master
  • 2,800 Answers
On this model LG TV 3 blink code is bad LED lamps in the panel. New strips can be purchased from shipjimmy
Posted on Oct 15, 2019
6ya staff
SOURCE:
Anonymous
  • 375 Answers
SOURCE: Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Posted on Oct 24, 2007
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
Posted on May 03, 2009
Anonymous
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
Chi Chu
  • 8457 Answers
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
Posted on Jan 27, 2010
eagle338
eagle338
  • 4889 Answers
SOURCE: lg model 42pm4m plasma monitor won't turn on, red
Does the tv make a clicking noise like its trying to turn on before the tv goes into standby and the LED starts flashing? I suspect this is due to a shorted component, most likely to be in the 5V(switching) line and just want to be a bit certain before we start testing the power supply.
Posted on Jul 31, 2011
Hi there.I have an lg led tv model 42LB5800 with no picture just sound. Also I can see the image with the torchlight. How can I fix it? thanks
The back light driver is bad. You could have lost the voltage from the power supply board to the led driver too. If you have a volt meter measure all the voltages on the power supply. The correct voltages are printed on the board next to the connector that goes to the rest of the TV. If they are all correct then the backlight driver is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 18, 2018 | LG Televison & Video
How do I get the Backlight to come on this TV?
What voltage are you getting on the LED lines that go to the lamps in the panel?
Jan 06, 2018 | LG Televison & Video
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
Lg tv 42lb5800-ug no image no sound I
Replace the TV you are over your head here.
Feb 23, 2017 | LG Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Televison & Video Logo
103 people viewed this question
Ekse
RONALD CARTER JR
