Hardware & Accessories Logo
JAIME TAMAYO Posted on Oct 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a ge5374-71L3 timer, I need to learn how to use it
Gene Haynes
Level 3:
  • Hardware & A... Master 5,391 Answers
  • Posted on Oct 28, 2019
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2606248
Points
14124
I have a hadco timer that needs to be reset....where can I learn how to do this?
Hadco T6 looks like Kitchler 15558WH
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
There are several brands of timer that look same-similar:
Open following link for images and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment and say which manual matches Hadco timer.
How do you timer record programs on logitech harmony 650
You would need to Learn the "record" and "timer" commands from your original remote - Remember, your Harmony remote can only Mimic the commands your original remote has!
Here's the user manual in case you have questions: http://images.harmonyremote.com/EasyZapper/Downloads/UserManual/Harmony650/enu/Harmony650_UserManual.pdf
As well, here's the link to learning these commands from your Original remote: http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9605
Elle
I have A Time All Model TB 211 and need to learn how to set the time with the pins. Have no manual. Using for my Xmas lites, on and off. Outdoor use.
There are two 2 basic types for mechanical timers: Pins and segments
geno_3245_149.jpgTimer pins flip in and out using fingernail.
geno_3245_150.jpg Timer segments lift up using small tool or fingernail
geno_3245_151.jpg Sometimes segments pull outward away from center
To check timer functions after setting pins or segments, manually rotate dial to and watch lights turn on and off.
Cant get to the off setup to program timer. the timer wont come on at the set time
The ST01C is unnecessarily difficult to program.
And the manual is confusing and unclear.
I wrote a page to help ST01C users who want specific on-off times (not dawn to dusk):
http://waterheatertimer.org/ST01C-program.html
I test and work with timers each day, and I had to fool with the ST01C for an hour or more.
First thing I learned is how to clear programs and start over.
Hold down ON-OFF and press reset button with paper clip.
Next thing I learned is to set programs before setting current day and time.
That way when you have to reset and start over, you are not re-setting current day and time each time.
Set current day and time after programming timer.
Timer doesn't have to be wired into the wall to set programs.
Here's a tip:
Program1 is ON
Program2 is OFF
Program3 is ON
Program4 is OFF
The key is watching the small light bulb icon on display when programming.
When light bulb is dark, that is ON
When bulb is is light, that is OFF
add a comment if you need more help
We have a taco timer aquastat that's pretty hot to the touch; and were not getting hot water to the house. Does it need replacing?
The pump has air in it and you need to purge out the air..
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
2answers
I need to set up my UPM RCT 100/TR430 remote light control and don't have the instructions. Can you help?
Press the learn button on the part that plugs in. Then press the "on" button for the remote and it should learn the code.
Using timer on Columbia watch
Try using your mode button to get to the "ST" screen. To start the timer, hit your st/stp button. To stop your timer, use the same button. To reset the timer, hit "reset". Hope this helps.
6helpful
2answers
I need the user guide for the time Tracker countdown timer
SET AUTO TIMER 1. Press and hold START and ENTER buttons at the same time for 3 seconds. 2. Press buttons until SET AUTO appears on the display. 3. Press ENTER. 4. Total Time: (Enter the total amount of time. It will automatically split between green, yellow and red lights). Use buttons to scroll through numbers and ENTER to accept. 5. Sound?: Do you want a sound effect at the start of the green light? 6. Yes/No: Use buttons to move cursor and ENTER to accept. 7. If yes, use buttons to scroll through sounds and ENTER to accept. 8. Repeat steps 7 and 8 for yellow and red sections. 9. Press MENU.
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
