SOURCE: LE error code
Yes this certainly is a sticking point, the inside of the panel is coated with black insulation, when it heats up the wires stick in it and eventually the wires break. The fix is as stated, splice the broken wires together, as well take some of the white insulation and put it in between the wires and the liner.
The errors that can arise from the sticky wires are numerous, LE, IE, etc. EI though is more than likely a siphoning problem. If your unit is noisey during operation, open the door, what is the water level? It should be at the second rim. If not, that is your first clue that the unit is siphoning. Make sure you have your loop in the drain hose.
Sgt 48
SOURCE: le code on ldf6810bb lg dishwasher
The LE error code can mean that the impeller is damaged or there is some debris blocking the the sump area underneath the filter or the wash motor has failed. In that order.
Remove the spray arm and filter (9 phillips screws) - inspect impeller for damage, with flashlight, look everywhere for debris (watch out for broken glass!) Reassemble and test.
If problems continue, schedule as service call focused on the wash pump/motor.
Good Luck!
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain
or work 'cause your outlet filter is clogged or an unusually heavy
load. The small door is on the left side front bottom of your washer.
Remove the door with a putty knife or thin butter knife inserted in the
middle top of the access panel door. Drain the water from the filter
housing by pulling the tube out of the clip and unplugging, allow it to
run into a bucket while the machine is in spin only mode. This mode is
acheived when the washer is first powered on press the spin button
until no spin is reached then run. Run in this mode until no water is
draining from the tube in the bucket. Keep the tube as low as possible.
When water has stopped coming out of the tube turn off the washer and
unplug from the wall. This step is important because this resets the
fault. Expect some water to come out when you open the filter housing
by turning counterclockwise until you can pull the filter from its
housing. Clean out your filter, return to housing turning clockwise
until seated and recap the tube and place in the holder, refit the
cover and plug back into the wall. Fixed. You may also need to lighten
the load a bit but I always try full on load anyways. If it fails again
just lighten, unplug wait >1 minute then replug and run.
Thanks.
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
