Question about Heavy Machinery
I have a 3.5 horse lazy boy chipper vac and it will start up but stops after a few seconds
  • 479 Answers
Check oil level and oil pressure switch, if not that then check fuel supply, pump and fuel lines.
Posted on Nov 02, 2019
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 41 Answers
SOURCE: I need a manual for
Have you tried to look it up online at the Lazy Boy website? I have been able to locate several parts and manuals there.
Posted on Jul 15, 2009
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: i have a craftsman h horse chipper/vac and i cant
Focus on the carburetor main jet.
On a float bowl carburetor, remove the bolt holding the bowl to the carb body. This is the main jet, clean the jet with spray carb cleaner, and also spray upwards into the center of the carb.
I have listed some basics to double check, not all may apply to your application. If you need more detail let me know. rwvanlue
Fuel Related issues that take a certain amount of time to appear
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter,
some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 13, 2009
I want to change the oil on my Yard Machines snow thrower with a 10hp Tecumseh engine and can't find the engine manual. What kind and how much oil should I use? Thanks - Zelmo
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
Dec 31, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a craftsman h horse chipper/vac and i cant
h) fuel pump
Nov 13, 2009 | Craftsman 4 Cycle Blower/Vac
I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
Nov 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Nead a setting for a carburetor 8 horse briggs&stratton
a good place to start is 2 turns out from bottom. dont over tighten the screw as this will damage the brass seat
Sep 05, 2009 | Troy-Bilt® Briggs and Stratton Chipper
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
I need a manual for a Lazy Boy chipper/vac model 47030
Jul 13, 2009 | Garden
Craftsman 6.5 Chipper vac
I have the same problem with no manual. You can go to managemyhome.com. & type in your model number & if it is in thier archives they will send a manual to you for free. Unfortunately they have not been able to find mine. Good Luck.
Nov 07, 2008 | Craftsman 6.5 Hp Chipper Vac
Heavy Machinery Logo
90 people viewed this question
Top Heavy Machinery Experts
STEVE
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
