Question about Refrigerators
Reset pur water filter-yellow light still comes on
Changed water filter- yellow light still comes on
    New Friend:
  • 6 Answers
You have to reset the cycle at the time of changing the filter. Check the manual for your fridge model as to the reset.
Posted on Oct 06, 2019
6ya staff
SOURCE:
FreeTech
Lee N.
  • 426 Answers
SOURCE: water not cold anymore
the tank in the fridge may have a block so only the warm water is coming in and not cycling thru the tank to be chilled? would be my best guess
Posted on Jun 20, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: just changed pur water filter on kenmore elite
this is normal. trapped air from the new filter will cause it to drip until all air has cleared. if you will run about a gallon of water thru the dispenser it should help if not stop the dripping all together. thanks peyton
Posted on Feb 21, 2009
Anonymous
SOURCE: Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Posted on Feb 25, 2009
Anonymous
SOURCE: How do I reset the change water filter light?
On my Fridge you press and hold the reset button for 3 seconds if that dont work has the filter been replaced?
Posted on Apr 04, 2009
odendahlt
  • 53 Answers
SOURCE: reset change filter light
Push the button in, that you will see, when you open your refrigerator door, hold it for about 10 sec. then let it go, it will turn green, If the light comes on, an says you need a new filter. That is not always true. do the same thing befor buying a new filter, to make sure you need a new filter.
Posted on Jul 03, 2010
How does the pur water filter work? Is it powered by a battery or is something else involved? My light will not light green or red after changing the filter sometime ago. Does it come apart?
it runs by water preasure. filter does not come a part. try to unplug the fridge for few minutes and plug back in. if that does not help see instruction to reset yje unit
Jan 20, 2015 | Refrigerators
The hold light and change filter light are on constantly and nothing seems to be working
Have you changed your filter, mine came n and I did not know to reset the filter changed are on the sensor.
Sep 24, 2013 | Kenmore 21.8 cu. ft. Side-By-Side...
PUR Faucet Mount Water Filter indicator light does not work
Take it loose from the faucet and flip the lever down on the filter in the on position. Take the cap off and remove the filter. Blow hard through it. You should hear a whirling noise of a gear, like a windmill. If not, I use a water dental pic to pulsate into it and clean it out. This is what makes the light work and when flow goes down, the light changes color. It's all mechanical. No battery. Just free up the gear so it turns freely to work the light. If standing in front of a mirror, you can actually see the light come on. PUR doesn't tell you this because they want you to purchase another one.
Dec 17, 2011 | Buck Plumbing
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Changed water filter on fridge ans now nothing comes out
Did you follow the filter instructions inside the box? Usually you have to pre-soak them for about an hour.
Some like Brita and Pur only say 5-10 min, but I usually do it for 15.
How long did you try to run water through the new filter? Its not an instant job.
Most fridges come with a "reset" button as well. Mine has one at the top near the door, even though the filter goes in the bottom of the Fridge.
Check your owners manual, make sure you put in the correct size filter too!
Hope this helps....
Mar 21, 2010 | KitchenAid KSRG25FKSS Side by Side...
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
How to replace pur water filter on a kenmore refrigerator
run a few gallons and you should be good to go
Apr 07, 2008 | Refrigerators
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
