Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana ABB2224DEW bottom freezer defrost problem
Amana ABB2224DEW bottom freezer is icing up and the refridge is not cold I can see ice build up on the condensor coil in the back of fridge must not be auot defrosting
is there a way to fix or do I need a tech?
  • 725 Answers
You have a defrost problem. You will need to replace your defrost system. Before you put the parts on, you need to completely thaw out your unit. You can do this by leaving it open all day or night or by placing a fan close to it with the door open. We have parts, so please give us a call and we'll be sure to ge the right parts out to you right away. We look forward to hearing back from you.
Posted on Sep 16, 2009
6ya staff
SOURCE:
Ice build up in the freezer
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
Jan 13, 2018 | Amana ARB1905C Bottom Freezer Refrigerator
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
My frig is making a buzzing sound
Well if the buzzing is coming from the compressor area then that could very well be the compressor relay. If the buzzing is coming from inside you might very well have ice building up, maybe a defrost problem causing the evap fan to maybe rub some ice. if it gets worse and the fresh food compartment begins to suffer and warm up then maybe a bad heater or defrost thermistat. All these components and a way to check em all can be found in this AMANA BOTTOM MOUNT SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 10, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
495 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
