I'm not finding much success and I do know that Hilti protects its' products. I would call Hilti direct.
Contact Hilti directly to inquire.
October 5, 2019 Tom
It is a Chuck Repair Kit. Not sure why people get hung up on part numbers. "I want THIS, to do THIS".
Hilti Te 17 Chuck Repair Kit 5017739 for sale online | eBayhttps://www.ebay.com › ... › Metalworking Drill Chucks
Find many great new & used options and get the best deals for Hilti Te 17 Chuck Repair Kit 5017739 at the best online prices at eBay! Free shipping for many ...
US$27.72 · In stock
SOURCE: how to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
SOURCE: where to buy a hilti 36v ni-cd battery and charger
call them direct at 1-800-879-8000 and they can find you a dealer close to your area or you can buy direct.
SOURCE: I have te10 hilti 36v rotory hammer drill that
It is more than likely the connections between the battery and the drill or the battery itself. If you look at the leads on the drill there are two large connections that can get bent along with smaller curved connection. If these connectors get bent It is hard to maintain a connection to the battery.
The 10A has not been sold in several years. I assume your batteries are old as well. Hilti has made great improvements over the years to their batterie tools. They still produce 36V hammer drills but now they are Lithium Ion batteries.
SOURCE: how can i find replacment
If you cannot get other brushes that fit the Hilti brush holders exactly, buy a set of brushes with similar pigtails and springs, if the brushes have these, but a bit larger on the sides. Carefully sand these down on find abrasive paper and on a flat surface till they slide snugly in the Hilti brush holders. Be careful, the carbon abrades very quickly and it is easy to take off too much carbon in just one or two rubs.
SOURCE: I need brushes for my
Here is some websites to purchase thse items
http://cgi.ebay.co.uk/Hilti-Hammer-Drill-Carbon-Brushes-T8-T10-TE5-TE10-25-/110554738665
http://www.amazon.co.uk/Carbon-brushes-Hilti-TE10-75556/dp/B003S7Q3TO
