Did you ever find your manual for the Elna SP2004? I have that sewing machine and the manual is somewhere. I can look for it if you still need it.
Possible 2004 manual. Use Comment menu item to let us know if this is what you are looking for:
https://www.manualslib.com/products/Elna-2004-719868.html
SOURCE: Elna 2002 Sewing Machine
Can't get a manual for you but here's how to wind a bobbin.
Guide your thread from the spool holder to the bobbin thread tension device on the top left side of the machine.(That's the round assembly that is about 1/2 inch in diameter with a screw in the center of it.) Pull the thread in the front and wrap it to the back and continue towards the bobbin winder on the right side top. Wrap thread around the bobbin, place the bobbin on the spindle sticking up. Release the handwheel(either by pulling out on the center of the wheel or twisting on the center of the wheel). Press on the foot control. It should stop winding when it is full.
To thread the machine
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way. Flat side to the back and it threads front to back
Sewman7
SOURCE: need a manual for Elna 6003 Quilters Dream sewing
Here is one - http://cgi.ebay.com/ELNA-6003-QUILTERS-DREAM-INSRTRUCTION-MANUAL-50-PGS_W0QQitemZ260342126317QQcategoryZ41246QQcmdZViewItem
Testimonial: "I am so pleased that I was able to get my manual and now know how much I can do with my machine. Keep up the good work. We all need to work together."
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
SOURCE: Manual for Elna lotus sp model 35 m703163
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual
