Question about Refrigerators
Crathco Frozen beverage machine 5711 grey matter is getting in the mix. Could this be caused by the use of bleach being used instead of sanitizer?
6ya staff
SOURCE:
Anonymous
SOURCE: Frozen Ipod
what you can do, is take the hold button, and push it back and forth maybe 2 or 3 times, than you hold down the "menu" utton and the center button at the same time for about 10 seconds and you will see it restarting with a black screen and the apple icon in the center than you can let go of the buttons and about 10 seconds it willl become brighter and you will see the icon, then you can get to all of your music or videos and such
Posted on Mar 30, 2008
Anonymous
SOURCE: Machine isn't Sanitizing! HELP!!!!!!!!!
Usually after three years the pump tube in the pump breaks down from exposure to the chlorine. You need to replaced the pump tube. Also the end of the tube that delivers the clorine could be plugged as chlorine is famous for crystalizing and plugging the tubes. Also check to make sure that the pump is running.
Posted on Aug 05, 2008
mirran
Mirko Blas
  • 515 Answers
SOURCE: I put sanitizer instead of espresso cleaner on machine
Rinse the machine with 3 tanks of water, if the coffee taste badly rinse little more.
/Mirran
Posted on Aug 08, 2008
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Posted on Feb 11, 2010
jeff964
  • 17 Answers
SOURCE: I have had my front
The manual that I have for my Frigidaire front loader says that this is normal and expected.
Posted on Jul 30, 2010
Frigidaire top load wont fill with water, and all other functions are working
Sounds like the solenoid fill valves where the hoses connect to the machine have gone bad.
Usually, it's just a matter of unplugging the machine, turning the water valves off a the supply connections, disconnecting the hoses, opening the entire top of the machine or removing the back panel, removing the plastic hot/cold water mixing valve assembly, getting a replacement assembly, and connecting the wires to the same connections after mounting the new valve assembly.
Close it up, reconnect the hoses turn the water back on, plug it in, and try it.
Apr 13, 2014 | Washing Machines
Making thumping noise
According to the manual it says there is a worn belt. Belt needs to be replaced.
Jan 19, 2014 | Grindmaster 5311 Bevgs - 1 Crathco Frozen...
Msd2651heb
If you replaced the 12002495 Defrost Control Board you will have two additional components to check. The 67004757 Defrost Thermostat and the 67004188 Defrost Heater Assembly You will need to manually defrost, unplug power and remove the rear panel in the back of the freezer to get to these two parts. I am adding a video on how to test the defrost heater and defrost thermostat. I will be here should you have questions Thanks Sea Breeze
Apr 26, 2013 | Maytag MSD2651 HE Side by Side...
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
My LG washing machine is making an awful sound when the tub is spinning. Regardless if there is a load of laundry in there or not? Then the LE code appears and it stops?
Most likely the rear seal has failed and thus water made it into the rear drum bearings. Bad news. You can generally confirm this by removing the rear access cover to see if there is sign of water leakage from the center of the drum in back. (rusty stains on the motor or actual water drips there) If so, rear bearing replacement and a new "spider" could run over $500. If no sign of water leakage, possibly only the inner spline of the motor rotor stripped out, which is an easy and MUCH less costly repair. (rotor carries at least a 5 year part warranty too. Newer models cover it up to 10 years)
Jun 26, 2011 | LG WM1814CW Front Load Washer
Drainage tubes in the Crathco granita machine broke out. Where can I get replacement parts. I am living in Nashville
if the black plasticbroke,you would need to replace the condensation tray. or, you could get a 3/8" double barb from a plumbing store and push it into the hole where it broke off and put the drain tube on the other end.
Aug 23, 2010 | Grindmaster Crathco granita machine, 2...
Unit powers up, lights work, motor is running but it is not getting cold. The unit was given to me. It is only 1 year old and it worked when I put it on the truck.
Beverage-Air are very good about helping the customer. Just be sure you don't leave out your serial number. The seem to get lost without that. Thanks, Sea Breeze
Nov 25, 2009 | Beverage-Air MT45 Beverage Cooler...
No elecrical current.
She's a fried!
Either a capacitor on the control board has popped, or the power cable somewhere inside the unit has worked loose and the circuit is open.
Mar 26, 2009 | Zanussi ZWF1650W Front Load Washer
Oil engine oil mix with water
sounds like you have a problem with the head or head gasket.Pulled out the spark plugs and see if you have any showing signs of leakage from head/gasket.
Oct 20, 2008 | 1989 Nissan Sentra 4 Door
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
