Question about Refrigerators
What melts the ice on the coils in order for them to drain out?
    Top Expert:
  • Refrigerators Master
  • 64,791 Answers
TURN THE POWER OFF
Posted on Oct 04, 2019
5 Suggested Answers
6ya staff
SOURCE:
mikedurland
Mike Durland
  • 481 Answers
SOURCE: Coils icing up?
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jun 29, 2008
nu267
  • 121 Answers
SOURCE: solid ice on coils
sounds like the compressor may not be shutting off, that may be the sensor (t-stat) or a freon leak, but usually only a partial part of the coil freezes up if it was low on freon an would not be cooling properly. if under a year old call manufacture. if 2-5 years old may still be under warranty if the repair is a freon issue. if its the sensor your looking at about 40. fot the part and roughly 75-95 for labor (depending were you take it too). check your purchase date and read your warranty 1st
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL. 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
EMAIL customerservice@allbrandsapliancerepair.com
we are a authorized servicer for delonghi if you have any aditional questions thank you
Posted on Jul 11, 2008
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: compressor on, coil frozen, no inside fan, ice melting.
This is a defrost problem (heater,timer,limit switch)
Posted on May 12, 2009
Philip
  • 949 Answers
SOURCE: drain hole under the evaporator coil in freezer keeps icing up
The drain may be clogged or running slow, flush some very hot water down the drain opening using a turkey baster or syringe. Here is some information I put together on drain freezing and how to clean them out in a little more detail. Let me know if this works for you. Thanks
https://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Posted on May 04, 2010
Ice forming under the freezer drawer & on drain tube water pooling in floor Cleared drain tube, what else?
Whirlpool corp., whom made this unit, had a bad design for the defrost drain tube by the compressor. Order part W10619951 and install. This is a kit to change out the current drain tube to a better one. You still have to defrost the frozen defrost drain tube but this will fix it for good.
Aug 01, 2015 | Maytag MFI2269VEM Monochromatic Stainless...
Water accumulating under veg.bins. Do not have ice maker hooked up. Whirlpool ET20DKXXN10 Model Mfg. date 1992.
you have a blocked drain in the freezer.when the machine goes into defrost a heater comes on and melts any ice that built up on the evap coil,the ice melts and goes down the drain and into a pan at the bottom where the compressor and condenser coil is and evaporates from the heat,your drain is blocked so the water can't go down the drain and it has nowhere to go but down into the fridge section.unplug the machine,remove all the food out of the freezer,remove the shelf and the inside back wall of the freezer.you might have to heat up the back panel with a hair dryer to get the wall out,when you have the back wall off melt any ice with the hair dryer,now you have to clear the drain,i use a steemer to blow down the drain but if you don't have a steemer stick a screw driver into the hole and the metal on the driver will heat up and help melt the ice,when you think the ice is melted in the hole get a turkey baster or something that will blow or push anything in the drain out,then pour hot water into the hole,if the water drains down then you're done if not keep hitting it with heat and hot water and try to clear the drain.hope this helps.
Sep 13, 2011 | Refrigerators
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Water running in refrigerater from freezer
this happens from a blocked drain in the freezer.when the machine goes into defrost a heater comes on in the freezer and melts the ice off of the evap coil.normally the water drains down through a hole under the evap. coil but yours is blocked with muck,ice and matbe some food particals but over the years slime forms in the drain.if you know how to put the machine into defrost do it or just unplug it,remove everything out of the freezer,remove the inner back wall of the freezer and with a hair dryer melt out all the ice,all the ice has to be melted off of the coil or anywhere you see it,now you have to clear the drain,i use a steamer to blast through the stuff in there to clean it but if you don't have a steamer you need something that will blow into the hole like a turkey baster or a shop vac,try vacing the stuff out and then put it on blow and try to blow the line out,if you try to snake something down there watch out the drain is plastic,also you can open the fridge door and in the middle of the seiling you can heat it up with the hair dryer to melt the ice in the drain and then blow through the line,when you think it's clear pour hot water into the hole,if it drains through then it's clear if not keep at it until you clear it.
Apr 17, 2011 | Whirlpool Refrigerators
Water is freezing over the freezer coils and dripping onto the top shelf. We have melted the ice and cleaned it out, but the problem came back. The refridgerator is working and so is the ice maker. Is...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jan 21, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have water coming from under the front of the fridge
Melt the sheet of ice with hot water or a hair dryer (be careful).
thats where the water is coming from. when in defrost the ice melt and rolls on top of that sheet of ice onto the floor. after you melt the ice also melt any ice under the evaporator. get it all!
Mar 22, 2010 | Refrigerators
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
The side by side freezer compartment water keeps freezing up in the bottom of the freezer - i took the back panel off and tried to melt the ice which has been accumulating and thus causing the water which...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 23, 2009 | Jenn-Air JCD2389G Side by Side...
My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
Feb 08, 2007 | Maytag MZD2665HE Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
