SOURCE: no ring,goes directly to voicemail
your phone is on 'do not disturb mode'. call your provider and ask how to shut it off. for telus mobility it is *79 then hit send
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
SOURCE: My phone on our Norstar system rings & rings
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
SOURCE: Incoming calls ring 3 times
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
SOURCE: my blackberry pearl wont receive calls. when
you have to check the actual sound profile and change the "Do not disturb" in the calls menu option to NO, hope it helps
