Health & Beauty Logo
Russell Grewell Posted on Oct 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
7 flashes indicate joystick problem - any easy fixes to try.-Jazzy select elite
Rob Hill
Level 3:
  • Elite Master 1,480 Answers
  • Posted on Oct 02, 2019
Rob Hill
Elite Master
Level 3:
Answers
1480
Questions
0
Helped
517651
Points
3838
Hi Russell, sadly not, you got a faulty joystick that needs to be replaced, I can do that cheaply,,
Regards
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Apr 01, 2009
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
oregoon
  • 175 Answers
  • Posted on Jul 09, 2009
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Anonymous
  • 5911 Answers
  • Posted on Aug 19, 2009
SOURCE: Hi. I have a Kenmore Elite Ultra Wash with Quiet
This may or may not help in your situation, but the following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Anonymous
  • 103 Answers
  • Posted on Nov 06, 2009
SOURCE: Jazzy Power select 7
Put the chair in free wheel mode and then back again and then turn the chair off then on again. Sometimes the chair will get out of gear just a littel.
Anonymous
  • Posted on Jul 30, 2010
SOURCE: Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
1helpful
What is code 8 and how do i repair it on jazzy select
Hi try monster scooter parts 800-798-0325...
service.toll free 1-800-798-0325.
email. [email protected]
code 8 is a possible joystick/controller fault
Cheers
How do I check power module and joystick module connections and wiring on my wheelchair?
hi Kathy, sadly there isn't a easy way to do this and you really need someone skilled in working with the powerchairs. This can be a joystick fault however make sure all connections are a tight fit ...
If you're based in the UK please give me a ring as I carry out free testing ...
Regards
Rob.
MY BATTERY INDICATOR LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT CHAIR WILL NOT MOVE
You are in locked mode. try turning the joystick on and pushing the horn twice. or if that did not work try turning the joystick on and pushing gimbal forward until it beeps and then back until it beeps. should be unlocked, scrolling up and down will stop and you can drive.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Light flashes 7 times
7 Flashes indicates a joystick trip. Turn off your chair, ensure the joystick is in center position without anything touching it and turn on chair. This should clear the 7 flash code.
This problem is quite common amongst power chair users. It typically occurs when something is pressing against the joystick as you are turning the chair on.
How do i fix the chair when the control flashes 9 times
Typically when a joystick flashes 9 times, it indicates there is a problem with the solenoid brake(s). I recommend contacting Pride Mobility for a Certified Technician in your area to look at this chair.
1helpful
Jazzy select contol panel all leds flash 7 times. what does that indicate?
This problem may depend on which main controller your chair has fitted. It should be a Penny & Giles GC controller. US versions should have a GC3 whilst here in the UK, it would be fitted with a GC2. However, the diagnostic flash codes for these two controllers should be the same. The reason im slightly confused is that you say 5 flashes mean your charger is connected at power up, when in fact it should be a Right Motor Wiring Fault. 9 flashes is indeed a Solenoid Brake Fault, or in other words, the wheelchair is in 'Free Wheel' as you have described. Therefore, IF your controller is in fact a Penny & Giles GC, 7 flashes would mean a Joystick fault. There is not much you can do to diagnose this other than checking connections between the Joystick and main controller. If these are OK, it is likely that a new Joystick controller will be required as having these fixed is usually not cost affective. Hope this is of some help to you.
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Don't run light go from left to right on a "Jazzy
carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
This jazzy Select 6 chair battery light keeps flashing 7 times and will not function.
alaker the 7 flashes indicate a joystick problem. Make sure that the joystick is centered before you turn the chair on. If it is centered and you still get the flashes then there is a problem that can only be fixed by a new joystick. Sorry for the bad news. Did Medicare pay for your chair? If they did then they will pay most of the replacement costs. Check with the provider that sold you the chair or with Roadrunner Mobility (On the web) to get it repaired Hope this helps
Top Elite Health & Beauty Experts
Rob Hill
Rob Hill
jws1013
Paul Carew
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
