Question about LG Kitchen Ranges
Lg STOVE SOME TIME COMES f11 code AND SOME TIME MAY TAKE ABOUT 1 HOUR AND HEAT STAY IN SAME NUMBER 200-220 Thanks
    Scholar:
  • 61 Answers
Hi, an f11 code means it's taking too long to heat up. Problem is most likely a worn bake ignitor. It's not drawing enough amps to open the gas safety valve. Call your local repair company. Hope that helps.
Posted on Oct 02, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 126 Answers
SOURCE: stove stays on and 30 min. later it starts beeping and F1 code
An F1 error code indicates a faulty keypad and /or ERC electronic control.
Posted on Jan 02, 2009
Anonymous
SOURCE: lg stove 30755st went to self clean and the oven shut off
I will NEVER Purchase another LG product!!!!! We have had our Range for 2 years, each time i've used the selfclean option, it has burned out our computer unit AND power pad! I've called LG, called Home Depot and the extended warranty department. NO HELP what-so-ever. LG, says there is nothing they can do! So we paid $1700 for a stove that we can NOT use the self clean feature because it will put us out for a week. Its not very frugal having to take a family of 6 out to eat for a week and a half straight! And this is NOT the first time its happened! DO NOT BUY LG!!!!!!!!!!! The Customer Service will NEVER work with you if you have an issue, and once you purchase it, its out of the store's hands!
Posted on Jun 23, 2010
kalamazoo222
Rick Hurd
  • 285 Answers
SOURCE: kenmore elite E3t F11 error code
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. See images below. Key #13 is the CCU and key #1 is the MCU.
The CCU (Central Control Unit) is located under the top along the side panel.
I recommend checking for loose wire connections at the MCU, CCU and motor. If you do not get any motor action at all, the MCU has likely failed.NOTE: Disconnect the power cord from the power source before removing the top and lower access panel. I recommend calling a service technician to diagnose and repair your washer.
Parts can be looked up and ordered at Sears PartsDirect
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services .
Posted on Dec 16, 2012
Lg oven f11 code
you need a qualified repair facility to check it out. the thermistor could be defective, or the control board.
Mar 24, 2018 | LG Ovens
F11 error how to fix it?
F11 code is to indicate a shorted key on the touchpad, which explains your symptom...Replace the electronic oven control.
What is your model #? Help Me Find My Model Number RepairClinic com
Jul 24, 2016 | Frigidaire Kitchen Ranges
Error code 07, heater keeps going to this code and switch off, takes ages to get it started to heat a little whilse and then going back to errorcode 07?
I take it you are talking about a pellet stove. You will probably have to call the company and get a new code. Have make and model handy when you call the company. Also you may be put on hold for a long time if they are busy with another customer. Whats nice is they stay on with you until your fixed. The last time my wait time was 2 1/2 hours. Hope this helps.
Apr 16, 2016 | Miscellaneous
I have LG stove and does not heat up. when I turned on it starts with 100c and starts making click click and after 4 5 minutes it shows on the control board the letter F and the number 7 what can be that.
Consult the papaer insert that comes in the range to find out what error code F 7 means. You might be able to Google it.
This sounds like a gas stove and you are talking about the oven.
Not having the model number nor being familiar with this LG I can only hazard a guess that the control board is locking out. Problem could be in the spark board or the gas valve. Less likely in the electronic board itself.
In future, always try to give as much info as you can as you are the one standing by the machine.
Oct 21, 2013 | LG LRE30755 Electric Kitchen Range
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
Lg stove 30755st went to self clean and the oven shut off
Mar 03, 2010 | LG Kitchen Ranges
Stove stays on and 30 min. later it starts beeping and F1 code
Jan 02, 2009 | Frigidaire FEF366 Electric Kitchen Range
F11 code on my HE4t washer
I fixed this myself for $30 and an hour of time.
Took hi-res photos and created a step by step guide.
www.he4tf11.blogspot.com
Dec 09, 2008 | Kenmore Elite HE4 Electric Dryer
Beeping F11 error on Frigidaire stove. We have to stut off from the breaker to stove beeping
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Jul 26, 2008 | Frigidaire Kitchen Ranges
What is this F-! mean
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example F11) - Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display & stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF & contact an authorized service agent.
Sep 03, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
46 people viewed this question
Top LG Kitchen Ranges Experts
Marvin
Marvin
Gene Pitts
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
