Question about Craftsman Garden
How to release parking brake on craftsman zero turn mower‘s
6ya staff
SOURCE:
Anonymous
SOURCE: engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Posted on Feb 12, 2009
Anonymous
SOURCE: Parking Brake Alarm
inset the key and switch on to position 2
Scroll through the warning display untill you get the service indicator apears
Press and hold the reset button on the left of the dash apnel for about 4 mins
You will be asked if you want to reset
Press anh hold the reset button again until you hear an audible warning
It should now show the new interval to a service
Posted on Apr 06, 2009
Anonymous
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
Anonymous
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
Anonymous
  • 13 Answers
SOURCE: ferris zero mower;eng.dies when releasing brake or control levers
Check seat SW.
Posted on Sep 29, 2009
Testimonial: "Thanks, I've had problems w/that sw. before,I'am going to run an ohms test on it. That tells me where to start."
Mower shuts off when parking brake is released
Is there a kill switch in the seat to stop the mower if no one is in the seat?
Oct 05, 2014 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
How do i release the parking brake on my brand new 2014 craftsman mower model #917.20385
If you are talking about driving it, just push foot on the regular brake and it should release. If you are talking about pushing it without any power on, you must pull the bypass lever on the back of mower and lock it out. sometimes you have to pull several times.
Jul 07, 2014 | Craftsman Garden
Why does mower die when brake released or mower engaged?
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine shuts off when you release the parking brake
More than likely you have the blade engaged, disengage the mowing blade and try the parking brake again
Apr 07, 2014 | Husqvarna Zero Turn Mower Z5426
Parking brake stuck in park on Craftsman 24 hp pyt9000
Have you tried pushing the brake pedal down all the way before releasing the park brake?
Aug 28, 2013 | Craftsman Garden
Craftsman Zero Turn
There are adjustments on the levers and the wheel motors. They are located under the seat and are a buckle style adjustment. One side is RH thread and the other is LH thread this enables the rod to lengthen or shorten depending on the turning of the buckle.
Dec 30, 2017 | Craftsman Garden
My husqvarna zero turn cuts off when i release the parking brake
safety switch problem-
1. under seat
2. PTO Switch
3. one for handle bars for the drive system
one has either come loose or has failed, most likely one id not fully connected.
Jul 21, 2010 | Husqvarna Zero Turn Mower Z5426
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
