Question about Bosch Washing Machines
I have a bosch aquatak 1300si which no longer switches on. I've tried changing the fuse, unplugging the hoses and reattaching. I can't see any physical damage of the machine or power cables.
    Master:
  • Bosch Master
  • 745 Answers
Check the board fuse with a multi meter
Posted on Oct 01, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: bosch aquatak 120i pressure washer/tetergent
Hi Guys there isnt a problem with your machine you just need to pull the end of the spray lance out -the lumpy bit where the water exits the machine (it kinda clicks out)
Posted on Jun 27, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony Camcorder Hi8 CCD-TRV46E Z00M u/s
Switch Control unit, having Stop, Play, FF, Rew, Pause and Tele-Wide switch at top of camera is cause of this problem. Its ribbon wire has been damaged / cracked, going to camera board. You need to replace that complete part because ribbon wire is not available individualy.
Posted on Aug 14, 2008
marionbagget
  • 718 Answers
SOURCE: My proline st44 microwave just suddenly went dead.
ProLine ST44 950 Watts Microwave
Since this machine is only sold in the UK I do not have a picture to point you to.
The problem is probably a blown thermal fuse. This fuse is located inside the machine and is for detecting overheating and fires. Sometimes age will cause it to fail. It's generally located near the air vent outlet.
If you handy with fixing gadgets you can check it.
Unplug the machine and remove the cover.
You can take an ohmmeter and test it. If it shows open you can replace it. It may be soldered in I am not sure. You can get replacements at an appliance parts store or Radio Shack®. There may be conventional fuses inside so you can check them also.
If nothing else is wrong it might be a door switch problem.
Wear on the interlock causing the crowbar microswitch to short the line and blow
the internal line fuse. The interlock, required by law, contains 3
switches - one switch sends a door-open signal to the
microprocessor, one opens the line and the third crowbars (shorts)
the power leads to the magnetron. If the crowbar switch activates
before the line switch opens, the line fuse gets blown. Just toss the crowbar switch.
Posted on May 14, 2009
sooty1111
SOURCE: bought bosch aquatak 100 pressure
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
Posted on Jan 20, 2011
David S.
  • 506 Answers
SOURCE: Eurolivee B215D - I press
What your amp is doing is going into protection mode. The Class D amplifier topology uses a Pulse width modulation scheme which allows the audio to be modulated onto a generated square wave or pulse train. This is then sent through the MOSFET Driver and then to the High Power MOSFETs that drive the load. The square wave with modulated audio is then filtered by a low pass filter and you are left with your audio. This is great because of the very high efficiency. The downside is that there are more links in the chain to fail. In your case it sounds like one or both of your power MOSFETs are bad and are causing the watchdog circuit to send a shutdown signal to the switching power supply, this is why it is turning off. It is a safety feature to prevent catastrophic failure of the board. (ie. burning the PCB to a crisp) A technician experienced in PCB level troubleshooting shoot be able to repair this for you. Let me know if you need anything good luck.
Posted on Jun 25, 2011
Which oil should be used for Bosch Aqautak 100 pressure washer
No oil mentioned in the instructions
https://www.tooled-up.com/artwork/ProdPDF/Aquatak110_manual.pdf
more information here
What is the quantity & the type of oil of Bosch Aquatak 10 pressure washer? Thanks
The link has changed in the meantime i see
You can use every EP zinc-free hydraulic oil what you want for it PERLUS ZF46 is a very good alternative
Bosch aquatak 100 plus pressure washer instruction manual - Fixya
www.fixya.com/support/t12257542-bosch_aquatak_100_plus_pressure_washer
Apr 1, 2012 - Hi, A 6ya expert can help you resolve that issue over the phone in a minute or two. Best thing about this new service is that you are never ... What is the quantity & the type of oil of Bosch ...
Jun. 19, 2016
Oil leaking from bosch aquatak 110 pressure washer
Nov. 16, 2013
What type of oil for aquatak 1250
Feb. 26, 2013
Re Bosch Aquatak 100 Plus pressure washer leaking an
Aug. 7, 2011
More results from www.fixya.com
Bosch Aquatak 100 (part1) - YouTube
? 2:34
https://www.youtube.com/watch?v=J1LE9bnUat0
Mar 20, 2011 - Uploaded by bogdanxp2000
Bosch Aquatak 100 high pressure cleaner, engine opened. ... How to Disassemble and Reassemble the Pump ...
Jun 04, 2018 | Bosch Garden
My pressure washer appears to have died.
does the motor have rust in it??the motor can be replaced
Jun 18, 2015 | Bosch AQUATAK GO Pressure Washer
Bosch aquatak
First off check your pressure wand / water nozzle make sure it's clean. if that doesn't help then it could be your water pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Jan 14, 2018 | Garden
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
Why don't i have any power on starting washer?
Could be in the spray handle and or nossle. Many years ago I brought 1 of these units ( Not by Bosch ), and the problem turned out to be in the spray handle...
Jun 05, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
1555 Centre Road
Clayton, VIC 3168
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Washing Machines Logo
53 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
