Fishing Logo
Earl Thomas Posted on Sep 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 33 rhino and a that 33 classic both want to release line when cast button is down.
Steve P
Level 3:
  • Fishing Master 3,912 Answers
  • Posted on Dec 08, 2019
Steve P
Fishing Master
Level 3:
Answers
3912
Questions
5
Helped
1307791
Points
15904
Maybe time to upgrade.. those are so cheap.... just throw them away and buy better ones!!
1 Related Answer
Anonymous
  • 69 Answers
  • Posted on Mar 23, 2009
SOURCE: wont cast
if u pushed the release button it will automatically lock if u real it wen u are finished casting make sure u put d catch bak on for the line to retrieve to ur reel
The line will not release when I cast
I am assuming you know at least something about fishing with a baitcast reel. If you do not, make sure you release the thumb button when you cast.
Chances are your line is either tangled or dirty on the inside. Also, the longer the line sits on the spool, the "curlier" it becomes, making it more difficult to get a good cast. I would suggest replacing your line.
If that doesn't help, then its possible that the release pin isn't releasing when the button is released. If this is the case, it is probably time for a new reel. Zebco 33's are inexpensive, and not really worth the trouble to try and repair- better to just invest in a new one.
How do I get my reel to keep from letting the line out while I'm holding down the cast button?
Hold the line with your index finger and against the rod itself. Then cast and release your hold
When releasing the thumb control to cast the line drops free (making it unable to cast)
you have to release the button after you start your cast, distance,height and length of cast is determined by where you release the button inside the forward arc of your cast, just like throwing a baseball.
Rhino 5200
power off unit. Hold the 6 key down, power on unit. Release the 6 key.
My pilot lights when I push the pilot button in but goes out automatically when I release it.
The Thermocouple, which keeps the flame lit, when in operation, but stops the gas flow if the pilot goes out has failed and will need to be replaced. You can purchase one online, directly from Blue Rhino.
Hope this helped you solve the problem.
5helpful
2answers
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Wont cast
1helpful
Having problems casting
To cast the line, you hold down the A button, make a casting motion with your arm, and let go of the A button near the top of your casting arc. Reeling in the line is as simple as moving the Nunchuk in a circular motion or pressing the A button. You can move the line either left, right, or back by moving the Wii Remote in the same direction and increase or decrease the drag on the line by pressing up or down on the D pad on the remote.
check out this little girl playing the game....you can see the motions she makes to cast: http://www.youtube.com/watch?v=ozG-s2N2xmo
For more info on controls, gameplay and cheat codes, visit this webpage:
http://www.gamespot.com/wii/sports/rapalatournamentfishing/review.html
On the left of the screen, you'll see box art image, further under that you's see the 'get it at best buy' and further under you will see where you can click for images, videos, and hints & cheats. Have fun! :)
Top Fishing Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Fishing Expert? Answer questions, earn points and help others
