Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
