Https://www.google.com search shows several listings
Example:
https://www.ebay.com/p/677663196
Walmart has "self learning" remotes, which pick up the signal and copy it. They are TV learner remotes. $12 and under. Yes, they also work for A/C unit remotes and Roku remotes too.
Just put the learner remote into receive mode, press each button, and press power, when done. Then use.
SOURCE: code number to use on universal remote control on a hyundai ditital tv model hy3438
just buy another universal remote which is having teach method... by using this remote u dnt need any codes... just once use the remote by which the appliance is working for teaching it then u can do any operation...
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
SOURCE: Universal remote code for an etec dvd player
I have the exact same model and it came without a remote. I was able to set it up so I can work it off of the Comcast 3 in 1 remote but the button layout is extremely confusing. I am currently looking for a replacement remote that would be easier to use since my wife can not get it to work at all off the Comcast one. Follow the instructions in the Comcast Remote Guide and you will find a code to make it work by doing a random search you just have to keep trying it will take some time.
SOURCE: Universal Remote Control code for Strong STB
i need the code of strong reciver for remote control
